Thread: Engine Coolant Temp Sensor
  1. Engine Coolant Temp Sensor
    Bourne End , Bucks
    Hi, all.
    Decided to get a VAGCOM cable and download the shareware software. Had to slightly modify the connector to seat it into the Passat. ( But was expect that ). I ran the autoscan, and the results came back as:
    VAG-COM Version: Release 409.1-US
    Chassis Type: 3B - VW Passat B5
    Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,57,58,76
    Address 01: Engine
    Controller: 038 906 019 BK
    Component: 1,9l R4 EDC G000SG 1061
    Coding: 00002
    Shop #: WSC 05311
    1 Fault Found:
    17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
    P1256 - 35-10 - - - Intermittent
    Readiness: N/A
    Address 03: ABS Brakes
    Controller: 8E0 614 111 AH
    Component: ABS/ASR 5.3 FRONT D10
    Coding: 00012
    Shop #: WSC 05314
    No fault code found
    I ran this test without starting the engine, can I assume that I do have a fault, although the car doesn't show any of the symptoms that other members have reported.
    I have recently replace the air flow meter. and have read the various topics and thanks to " cbrpaul " detailed instructions it looks like a simple job.
  2. Re: Engine Coolant Temp Sensor
    Belgrade,Serbia
    Just clear the code if it comes back replace temp.sensor
  3. Re: Engine Coolant Temp Sensor
    Bourne End , Bucks
    Not sure how to clear the code , I only have the shareware version 409.1, it tells me to use the Professional version for this function. Do I still have to register the shareware version, or buy the pro version in order to clear this fault code?
    Thanks.
  4. Smile Re: Engine Coolant Temp Sensor
    Bourne End , Bucks
    Just a quick update, I replaced the sensor, only issue I had was removing the plastic circlip, which just pulls downwards from the tab located at the bottom.
    Used about 3/4 litre of coolant, after a quck drive round the block. The engine now runs about 200 rpm lower on tick over and doesn't sound so rough when driving.
    I haven't done a code clear yet, ( need to read up on that first ) .
  5. Re: Engine Coolant Temp Sensor
    Belgrade,Serbia
    when you register your version then go to fault codes.When you see what the cose is then press clear codes.Afther that whate to see if the code will show uo again.If not you are OK.
  6. Re: Engine Coolant Temp Sensor
    Bourne End , Bucks
    Thanks, I give it ago.
  1. A4 B6 1.8T coolant temp sensor location?
    By lwodrumm in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-12-2007, 05:41 PM
  2. coolant temp sensor in APT 1.8 20v
    By redman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-09-2007, 02:23 PM
  3. mk3 coolant temp sensor
    By pazur in forum Vento - 1994 - 1998
    Last Post: 05-08-2007, 05:53 PM
  4. Replacing Coolant Temp Sensor in a Mk4 AGU 1.8T
    By Si_1.8T in forum Golf MK4 - 1999 - 2004
    Last Post: 19-07-2007, 07:48 PM
  5. V6 coolant temp sensor problem
    By arrowmaker in forum Archive posts
    Last Post: 27-03-2007, 08:30 PM
