Thread: Infotainment issue - diagnostic advice VCDS
  1. Infotainment issue - diagnostic advice VCDS
    Mar 2016
    Sheffield
    Hi All,
    I've been having issues with my Audi Infotainment system on my 2008 A5 3.0 TDI Sport and would really appreciate some advise on how to diagnose/fix.
    Symptoms:
    - Plays for a while and then switches off and tries to restart.
    - Happens on all settings (CD, SD, FM, Phone and DAB) although seems to be more frequent on FM waveband.
    Actions taken:
    - Tried to replicate with a pattern i.e. lights on/off, CD on/off, ESP on/off etc. and there doesn't seem to be a pattern.
    - Used VCDS to get error codes.
    - Audi experienced mechanic said it may relate to a retrofit Telephone (I didn't retrofit the telephone module or know about it) module however this isn't the module that is giving an error and he didn't want to get involved in fixing it.
    Additional info:
    - Had to get a replacement passenger airbag ECU fitted a month ago as the original failed
    - No other issue to date....yet
    Questions:
    - Why is there 2 entries for radio?
    - Does anyone know what I need to disable on a modular basis to rule out specifics i.e. telephone, DAB etc.?
    Thanks for any advice in advance
    VCDS Scan details:
    Tuesday,15,March,2016,12:36:52:40271
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 15.7.4.1
    Data version: 20160216
    Ross-Tech: Home
    VIN: WAUZZZ8T88A008804 License Plate:
    Mileage: 91570km-56898mi Repair Order:
    Chassis Type: 8T (8T0)
    Scan: 01 03 05 06 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 77
    VIN: WAUZZZ8T88A008804 Mileage: 91570km-56898miles
    01-Engine -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    06-Seat Mem. Pass -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    47-Sound System -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: Sporadic communication error 1000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CAPA) Labels: 059-907-401-V1.clb
    Part No SW: 8K0 907 401 HW: 8K0 907 401
    Component: 3.0TDI EDC17 H01 0008
    Revision: --H01---
    Coding: 01140023180F0118
    Shop #: WSC 06325 000 00000
    ASAM Dataset: EV_ECM30LTDIA5 A01009
    ROD: EV_ECM30LTDIA5.rod
    VCID: 68D8058493EE947ED6-803C
    1 Fault Found:
    5418 - Glowplug for Cylinder 6 (Q15)
    P161F 00 [101] - Open Circuit
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 91571 km
    Date: 2016.03.15
    Time: 12:03:33
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
    Part No SW: 8K0 907 379 J HW: 8K0 907 379 J
    Component: ESP8 quattro H03 0190
    Revision: -------- Serial number: --------------
    Coding: 1B0500
    VCID: 4088FD24D31E8C3E3E-8014
    No fault code found.
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 289 C HW: 8K0 907 289 C
    Component: BCM2.01 H38 0253
    Revision: 00002001
    Coding: 031000
    VCID: 397E90C0B0C4DDF679-806C
    Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
    Component: FBSAUDIB8 IDG H34 0050
    Subsystem 2 - Part No SW: 8K0 905 852 A HW: 8K0 905 852 A
    Component: ELVAUDIB8 H34 0039
    Address 06: Seat Mem. Pass (J521) Labels: 8T0-959-760.clb
    Part No SW: 8T0 959 760 HW: 8T0 959 760
    Component: MEM-BFS H08 0027
    Revision: AA000000 Serial number: 00001001016436
    Coding: 08217025002444441000
    VCID: 55A63C703C9C19967D-8000
    Address 08: Auto HVAC (J255) Labels: None
    Part No SW: 8T2 820 043 G HW: 8T2 820 043 G
    Component: KLIMA 3 ZONEN H04 0093
    Revision: D0000000 Serial number: 0125.07.070028
    Coding: 36060000
    VCID: 36649BFC81DA328E94-8062
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 C HW: 8K0 907 279 C
    Component: BCM1 1.0 H19 0253
    Revision: 04019001 Serial number: 00000000027954
    Coding: 260050910014AF010009000000005D5D001D03880001014100 0000
    Shop #: WSC 00861 210 91441
    VCID: 2F6AAE987E800346D7-807A
    Subsystem 1 - Part No SW: 8T2 955 119 B HW: 8J2 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 040707 H11 0040
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8T0 955 559 HW: 4E0 955 559 B
    Component: RLS H12 0001
    Coding: 02532C
    Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
    Component: E1 - LDS H07 0070
    Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
    Part No SW: 8K0 919 475 HW: 8K0 919 475
    Component: PARKHILFE 4K H06 0003
    Revision: 11001001 Serial number: 46130719002574
    Coding: 000001
    VCID: 76E45BFCC15A728E54-8022
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 HW: 8K0 959 655
    Component: AirbagVW-AU10 H27 0334
    Serial number: 0038GD110A7G
    Coding: 30323232333030303030554A305238543053
    ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 7AFC4FCCFD4216EE30-802E
    Crash sensor for side airbag; driver side:
    Serial number: 6334LSME1B6C5D53S
    Crash sensor for side airbag; front passenger side:
    Serial number: 6344LSME1575005C8
    Crash sensor for side airbag; rear; driver side:
    Serial number: 6352QSME324D3969Q
    Crash sensor for side airbag; rear; passenger side:
    Serial number: 6362QSME3244383DI
    Crash sensor for front airbag; driver side:
    Serial number: 63734SME2C2E0B357
    Crash sensor for front airbag; front passenger side:
    Serial number: 63834SME2C2C184BB
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 B HW: 8K0 953 568 B
    Component: Lenks.Modul H09 0011
    Revision: -------- Serial number: 90304GGD0001P
    Coding: 000016
    Component: E221 - MFL H02 0003
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8T0 920 980 M HW: 8T0 920 980 M
    Component: KOMBIINSTR. H20 0136
    Revision: 00500000 Serial number: 6C122ML77
    Coding: 2305010002002600010000
    Shop #: WSC 06325 123 12345
    VCID: 4586EC30CC3CA9160D-8010
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 D HW: 8T0 907 468 D
    Component: GW-BEM 5CAN H04 0084
    Revision: GA801030 Serial number: 3000G076068036
    Coding: 000003
    Shop #: WSC 00861 210 82411
    VCID: 428CF72CDD129E2E28-8016
    Subsystem 1 - Part No SW: 8K0 915 181 HW: 8K0 915 181
    Component: J367-BDM H06 0150
    1 Fault Found:
    01304 - Radio
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 216
    Mileage: 91574 km
    Time Indication: 0
    Date: 2016.03.15
    Time: 12:10:29
    Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
    Component: MEM-FS H08 0027
    Revision: AA000000 Serial number: 00001001016441
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 A HW: 8K0 959 793 A
    Component: TSG FA H09 0149
    Revision: Serial number: 0Ha
    Coding: 0110022240012201
    VCID: 3E7483DCA9EAFACE4C-806A
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0105548373
    Coding: 011B068200390440002000
    Subsystem 1 - Part No: 8K0 951 177
    Component: DWA-Sensor H02 0030
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H03 1301
    Address 47: Sound System (J525) Labels: 8T0-035-223-BOC.clb
    Part No SW: 8T0 035 223 L HW: 8T0 035 223 B
    Component: DSP Prem H11 0170
    Revision: 00H11001 Serial number: 34832000205801
    Coding: 0203010301
    VCID: 377A96F886D0CB868F-8062
    2 Faults Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 176
    Mileage: 91571 km
    Time Indication: 0
    Date: 2016.03.15
    Time: 11:53:58
    Freeze Frame:
    Voltage: 11.70 V
    Temperature: 17.0°C
    Temperature: 26.0°C
    Bin. Bits: 00000001
    01304 - Radio
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 5
    Reset counter: 216
    Mileage: 91574 km
    Time Indication: 0
    Date: 2016.03.15
    Time: 12:10:29
    Freeze Frame:
    Voltage: 14.30 V
    Temperature: 22.0°C
    Temperature: 31.0°C
    Bin. Bits: 00000010
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 A HW: 8K0 959 792 A
    Component: TSG BF H09 0149
    Revision: Serial number: 0˜a
    VCID: 3D7684D0A4ECE1D655-8068
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 C HW: 8K0 907 801 C
    Component: EPB Audi B8 H03 0040
    Revision: 00000003 Serial number: 00000000010324
    Shop #: WSC 00000 000 00000
    Address 55: Headlight Range Labels: 8K0-907-357.clb
    Part No: 8K0 907 357
    Component: Dynamische LWR H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000002
    VCID: 72EC67EC6D326EAE78-8026
    Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
    Part No SW: 8T2 035 186 A HW: 8T2 035 186 A
    Component: Concert3 DAB H10 0121
    Revision: 00000505 Serial number: AUZ5Z6G1000994
    Coding: 000300820104CD0203DB870100
    Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
    Component: Display
    Address 77: Telephone Labels: RETROFIT77.lbl
    Part No SW: KTC 364 31P HW: KTC 364 31P
    Component: SWP:3.24.7 H24 0213
    Revision: 00000000 Serial number: 00000000000000
    Shop #: WSC 21977 142 74100
    VCID: 3362A2E852A827A6B3-8066
    End-------------------------(Elapsed Time: 02:34)--------------------------
    Craig
  2. Re: Infotainment issue - diagnostic advise VCDS
    Ambler, PA, USA
    My quick thought on this is that the CAN gateway is coded incorrectly.... no suggestions 'cause it would take a bunch of playing to figure it all out. Ya need someone with boots on the ground and experience who is willing to work through it with ya.
  1. VCDS diagnostic - North East (Stockton \ Middlesbrough)
    By cassy in forum VCDS - Help Requests
    Last Post: 03-06-2025, 01:05 PM
  2. advice on buying VCDS/VCDS-lite
    By borakev in forum VCDS - General Questions
    Last Post: 16-04-2019, 05:20 PM
  3. Question Dealer says faults reported by VCDS don't appear on their VW diagnostic system
    By MadUKDiver in forum Golf MK7 - 2013 - 2019
    Last Post: 23-09-2014, 10:34 PM
  4. Question Advice please - What diagnostic's to buy?
    By charlescampion in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-10-2010, 05:17 PM
  5. diagnostic tool advice wanted
    By kateb in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 12-04-2010, 09:05 PM
