Thread: Im In The Dark Plz Help
  1. Im In The Dark Plz Help
    Jun 2007
    ok prob is i aint got any lighting for the dash when drivin at night already tried fuse and now im stumped any clue would be great
    its an '88 audi 80 1.8
    is this gona be an easy fix or do i just buy a torch
    cheers in advance for you help
  2. Re: Im In The Dark Plz Help
    somerset
    8 Post(s)
    Just a shot in the dark, but is the dimmer knob turned fully anti clockwise? try turning it the other way, dash lights go out completely when dimmer is turned anti clockwise. Worth a go! Its located between the clocks, to the left of the mileage zero one.
  3. Re: Im In The Dark Plz Help
    Jun 2007
    Tried That But No Joy Turned It Both Ways
    Think I Might Be A Loose Wire But Dont Fancy Taking The Dash Out To Find Out It Aint As Need Car For Work So In Short Term Gettin A Torch
  4. Re: Im In The Dark Plz Help
    Jun 2007
    Gwent
    As far as I know, the number plate lamps and the glovebox lamp are on the same circuit, problems with these, or their wiring/switches can cause the instrument illumination to fail. Also the circuit board in the instruments can be troublesome, often these problems are 'dry joints', resoldering any suspect terminals can fix it.
    Some good info in this thread:
    https://www.vwaudiforum.co.uk/forum/s...?t=8426&page=2
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  5. Re: Im In The Dark Plz Help
    Aug 2007
    Midlands, Uk.
    Quote Originally Posted by big_alans_80 View Post
    I know it sounds funny, but it'll be all your dash bulbs blown. I had the same problem in my 94 80 TDi, changed all the bulbs and was fine. They're orange housing bulbs, 1.0 Watt I think, I purchased replacements on the internet.
  6. Re: Im In The Dark Plz Help
    Apr 2007
    Kent
    Quote Originally Posted by scotty33 View Post
    I now have exactly the same problem, none of my dashlights, centre console gauges or heater controls light up. I've checked the circuit board already, but not the glovebox lamp. That has just reminded me, the night when the dashlights stopped working, a spring fell out of my glovebox, that must be the answer!
    Thank you!
    P.S. Will let you know how I get on.
  7. Re: Im In The Dark Plz Help
    paul20v Guest
    hi
    one of mine dropped all dash lights its more than likely the dimmer control i removed mine and bypassed it with a little soldering i dont like the dimmers anyway
  1. STEP INTO SUMMER WITH THE NEW BEETLE CABRIOLET DARK FLINT
    Last Post: 29-03-2005, 09:28 PM
