Thread: VCDS 15.7.1 Meas. Blocks-08 not active!
Results 1 to 10 of 11
Hybrid View
  1. VCDS 15.7.1 Meas. Blocks-08 not active!
    Sep 2015
    Forres, Scotland
    23 Post(s)
    Hi everyone! I bought VCDS 15.7.1, instal software, but when I run program and connected Meas. Blocks-08 is unable ( grey color)
    Is anything what can Ido with it?
  2. Re: VCDS 15.7.1 Meas. Blocks-08 not active!
    Feb 2013
    Maidenhead Berks UK
    7 Post(s)
    Need a few more details such as car model and engine specification. Dump of VCDS auto-scan would also help.
  3. Re: VCDS 15.7.1 Meas. Blocks-08 not active!
    Sep 2015
    Forres, Scotland
    23 Post(s)
    Thanks 32110! Audi A6 C6 2.0 tdi 170 Ps , engine code CAHA, first reg. Marcu 2011, model year September 2010.
    Auto-scan will add later!
    Code:
    Friday,11,March,2016,15:39:30:05031
    VCDS Version: 15.7.1.0 (x64)
    Data version: 20150904
    Ross-Tech: Home
    VIN: WAUZZZ4F0BN045362   License Plate:
    Mileage: 97580km-60633mi   Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 03 05 08 09 0E 15 16 17 19 42 46 4F 52 53 55 56 5F 62 72
              76
    VIN: WAUZZZ4F0BN045362   Mileage: 97580km-60633miles
    01-Engine -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
    Address 01: Engine (J623-CAHA)       Labels: 03L-906-022-CAG.clb
       Part No SW: 03L 906 022 FG    HW: 03L 906 022 FG
       Component: R4 2,0L EDC   H14 6420
       Revision: 11H14---    Serial number:
       Coding: 0105002C18072118
       Shop #: WSC 02145 785 00200
       ASAM Dataset: EV_ECM20TID03L906022FG A01007
       ROD: N/A
       VCID: 6FEA4B93B68EAB46B4-803A
    No ASAM data for: "EV_ECM20TID03L906022FG" (AU56)
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
       Part No SW: 4F0 910 517 AK    HW: 4F0 614 517 AT
       Component: ESP8 front      H03 0060
       Revision: 00000000    Serial number: 00000000000000
       Coding: 0020859
       VCID: 6DD6519B7482595686-8038
    Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
       Component: FBSAUDIC6 ELV   H05 0130
       Revision: 00H05000    Serial number: 10602901710735
       Coding: 0000017
       VCID: 254669BBECF2A1160E-8070
       Subsystem 1 - Part No: 4F0 910 132 D
       Component: FBSAUDIC6 EZS   H03 0020
       Subsystem 2 - Part No: 4F0 910 220 D
       Component: FBSAUDIC6 IDG   H01 0054
    Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
       Part No SW: 4F0 910 043 B    HW: 4F2 820 043 AA
       Component: KLIMABETAETIGUNGH30 0080
       Revision: 00000076    Serial number: 00000000763918
       Coding: 0001044
       VCID: 1D36415BC4A269D656-8048
    1 Fault Found:
    00797 - Sunlight Photo Sensor (G107)
                009 - Open or Short to Ground
                 Freeze Frame:
                        Fault Status: 01101001
                        Fault Priority: 3
                        Fault Frequency: 254
                        Reset counter: 228
                        Mileage: 92027 km
                        Time Indication: 0
                        Date: 2015.12.14
                        Time: 17:52:33
    Address 09: Cent. Elect.        Labels: 4F0-910-279.lbl
       Part No SW: 4F0 910 279 N    HW: 4F0 907 279
       Component: ILM Fahrer      H22 0320
       Revision: 00000000    Serial number: 4F0907279
       Coding: 0013121
       Shop #: WSC 02335 785 00200
       VCID: 346084FF5728C89E89-8060
       Subsystem 1 - Part No: 4F2 910 113 C  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H11 0040
       Coding: 00056595
       Shop #: WSC 02335
       Subsystem 2 - Part No: 8K0 910 557   Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH04 0003
       Coding: 00146221
       Shop #: WSC 02335
    Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
       Part No SW: 4F0 035 110 A    HW: 4F0 035 110
       Component: CDC-MP3-Alp   H44 0140
       Revision: AA001001
       VCID: 1526597BFC9231969E-8040
    Address 15: Airbags (J234)       Labels: 4F0-910-655-10.clb
       Part No SW: 4F0 910 655 Q    HW: 4F0 959 655 G
       Component: Airbag AU1042 H07 0200
       Revision: --------    Serial number: 003F90048297
       Coding: 30314236303630303033554A305234463053
       Shop #: WSC 02324 785 00200
       ASAM Dataset: EV_Airba10AURB4 001001
       ROD: EV_Airba10AURB4.rod
       VCID: 3566B9FB9452D196BE-8060
       Crash sensor for side airbag; driver side:
       Serial number: 3574SRB40000D0E54A06
       Crash sensor for side airbag; front passenger side:
       Serial number: 3584SRB40000D0D89A7L
       Crash sensor for side airbag; rear; driver side:
       Serial number: 3516HRB40220BQMKVBE+
       Crash sensor for side airbag; rear; passenger side:
       Serial number: 3526HRB402VFR6EV643%
       Crash sensor for front airbag; driver side:
       Serial number: 3554NRB400005D03CF12
       Crash sensor for front airbag; front passenger side:
       Serial number: 3564NRB400005D5664C5
    Address 16: Steering wheel        Labels: 4F0-910-549.lbl
       Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
       Component: J0527               0530
       Revision: 00H05000    Serial number: 90025103180029
       Coding: 0102041
       VCID: 275A63B396FEB3063C-8072
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: E0221           H02 0100
    Address 17: Instruments (J285)       Labels: 4F0-920-xxx-17.clb
       Part No SW: 4F0 920 983 G    HW: 4F0 920 983 G
       Component: KOMBIINSTR.   H09 0209
       Revision: 00000000    Serial number: FKW250ACA
       Coding: 2F74090502002600010400
       Shop #: WSC 02391 823 56573
       VCID: 306888EF6330F4BEED-8064
    Address 19: CAN Gateway (J533)       Labels: 4F0-907-468.clb
       Part No SW: 4F0 907 468 M    HW: 4F0 907 468 F
       Component: GW-BEM 4CAN-M H06 0035
       Revision: LB100029    Serial number: 2900L10B08800F
       Coding: 000B03
       VCID: 397EB5CBB04A35F65A-806C
       Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
       Component: J367-BDM  H07 0125
    Address 42: Door Elect, Driver (J386)       Labels: 4F0-959-793.clb
       Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
       Component: TSG FA        H12 0361
       Revision:             Serial number: 0008000120978
       Coding: 011F06204041410001
       VCID: 4898C00FFBA05C7ED5-801C
    Address 46: Central Conv.        Labels: 4F0-910-289.lbl
       Part No SW: 4F0 910 289 N    HW: 4F0 907 289 N
       Component: Komfortgeraet   H29 0250
       Revision: 02500029    Serial number: 01384320510000
       Coding: 0139771
       VCID: 3566B9FB5C52D196BE-8060
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H05 1501
       Subsystem 2 - Part No: 4F0 910 177
       Component: Innenraumueberw.H01 0020
    Address 4F: Centr. Electr. II        Labels: 4F0-910-280.lbl
       Part No SW: 4F0 910 280     HW: 4F0 907 280 A
       Component: ILM Beifahrer   H14 0100
       Revision:             Serial number: 00000000751567
       Coding: 0001104
       VCID: 5EB40657892432CE0F-800A
    Address 52: Door Elect, Pass. (J387)       Labels: 4F0-959-792.clb
       Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
       Component: TSG BF        H12 0361
       Revision:             Serial number: 0008000121947
       VCID: 479AC333F6BE5306DC-8012
    Address 53: Parking Brake        Labels: 4F0-910-801.clb
       Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
       Component: EPB  CEFC0090   H05 0090
       Revision: --H05---
       Coding: 0000111
       VCID: 214E7DABF8DA4D3672-8074
    Address 55: Headlight Range        Labels: 8P0-907-357.lbl
       Part No: 8P0 907 357 H
       Component: Dynamische LWR  H01 0010
       Revision: 00000001    Serial number:
       Coding: 0000003
       Shop #: WSC 02325 785 00200
       VCID: 3F8ADBD36E6E1BC664-806A
    Address 56: Radio (R)       Labels: Redir Fail!
       Part No SW: 4G0 035 056     HW: 4G0 035 056
       Component: Radio U STD   H52 0051
       Revision: AB001007    Serial number: 469K60A7615429
       Coding: 010003020100000000
       VCID: 5EB40657492432CE0F-800A
    Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
       Part No SW: 4E0 035 652 E    HW: 4E0 035 652
       Component: B-BN-EU       H58 0147
       Revision: --------    Serial number: 349KZ0AB001740
       Coding: 010101000002CBFD03000F0DEF6300030001
       VCID: 234277A322C65F2660-8076
       Subsystem 1 - Part No: 4G0 919 884 J
       Component: EUR 2011  1204
       Subsystem 2 - Part No SW: 8T0 919 604     HW: 8T0 919 604
       Component: DU6 Basic  H42 0084
       Subsystem 3 - Part No SW: 4F0 910 609 E    HW: 4F2 919 611 H
       Component: Bedienteil MM  H01 0060
    2 Faults Found:
    03157 - Functionality limited due to Communications Disruption
                000 -  -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 32
                        Mileage: 87905 km
                        Time Indication: 0
                        Date: 2015.10.06
                        Time: 16:59:59
                 Freeze Frame:
                        Bin. Bits: 00000010 00100000
                        Bin. Bits: 00000000 00000000
    02612 - Audio Wire Adapter Set
                011 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01101011
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 230
                        Mileage: 87528 km
                        Time Indication: 0
                        Date: 2015.09.28
                        Time: 09:15:40
                 Freeze Frame:
                        Voltage: 11.80 V
    Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
       Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
       Component: TSG HL        H11 0361
       Revision:             Serial number: 0008000123058
       Coding: 010E04204041220001
       VCID: 4684CE37F1B44A0E27-8012
    Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
       Component: TSG HR        H11 0361
       Revision:             Serial number: 0008000123059
    Address 76: Park Assist        Labels: 4Fx-910-283.lbl
       Part No SW: 4L0 910 283 B    HW: 4L0 919 283 B
       Component: Parkhilfe 4-Kan H03 0500
       Revision: 00H03000    Serial number: 37231032302074
       Coding: 0200006
       VCID: 295E658B80EA85762A-807C
    End-------------------------(Elapsed Time: 03:34)--------------------------
  4. Re: VCDS 15.7.1 Meas. Blocks-08 not active!
    Ambler, PA, USA
    I presume this was in the engine controller? Your car uses UDS language in the engine controller. UDS does not use the 08 Measuring Values. You must use the Advanced Measuring Values button - which I think you will find is not "greyed" out.
  5. Re: VCDS 15.7.1 Meas. Blocks-08 not active!
    Sep 2015
    Forres, Scotland
    23 Post(s)
    Quote Originally Posted by bearthebruce View Post
    You are right Bruce! Why newer cars can use just UDS?
  6. Re: VCDS 15.7.1 Meas. Blocks-08 not active!
    Ambler, PA, USA
    That my friend, will need to be asked of the VAG engineers. Certainly they did not consult us and their UDS shenanigans have made our lives much more complex. Our design staff is as frustrated as it gets when it comes to all the changes we have had to implement with the introduction of UDS in 2009. Those changes have continued in every model year since, making the task of keeping our tool up with all their changes really difficult. When you ask around, some say Ross-Tech is slipping. Well, yeah, we are. Not because we don't make the effort - but because the effort is exponentially more difficult these days.
    08 Measuring Values are going to go away we are convinced. New models from VAG will all use UDS. All will require use of the Advance Measuring Values.
    Have you looked at the adaptations and all the changes there? How about Basic settings? Output tests? The complexity is daunting.
    Know that our guys are working their bottoms off trying to stay current with all the changes. Remember, VAG does nothing to help us. We have to mine the information and then provide it in our tool for all to use - including all the other scan tool manufacturers who use our information to make their tools. We are still the most complete in the aftermarket and still try to have information on current model year. Sure, there a couple who have found a few sources for a platform or two which we have not found. But in the main, Ross-Tech VCDS is still your go to tool if you choose not to use the factory tools.
  7. Re: VCDS 15.7.1 Meas. Blocks-08 not active!
    Sep 2015
    Forres, Scotland
    23 Post(s)
    Do you know Bruce where in Advanced measuring values I can find torsion values (camshaft timing ) ?
  8. Re: VCDS 15.7.1 Meas. Blocks-08 not active!
    Ambler, PA, USA
    Without seeing an autoscan that tells us the data from the control module so we might be able to look things up, no, I cannot guess. Post an autoscan from the vehicle and perhaps we can do some research for you.
    With UDS, the data is not standardized.
  9. Re: VCDS 15.7.1 Meas. Blocks-08 not active!
    Sep 2015
    Forres, Scotland
    23 Post(s)
    Ok Bruce! It is fair!
  1. Active Braking Guard too active?
    By tadziak in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 01-09-2016, 09:07 PM
  2. Retrofit Active Lane Assist VCDS scan
    By soft in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-07-2014, 09:25 AM
  3. How-to ?? measure blocks ??
    By b5passat99 in forum VCDS - General Questions
    Last Post: 26-10-2013, 04:02 PM
  4. Vcds measure blocks for dummies
    By djah in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-05-2012, 05:30 PM
  5. LOC`s in Adv Meas Blks
    By johnvw in forum VCDS - General Questions
    Last Post: 12-04-2012, 10:06 AM
