Thread: BKP 2.0tdi oil pump replaced with a CR oil pump
  1. BKP 2.0tdi oil pump replaced with a CR oil pump
    Mar 2016
    Castlewellan Co Down
    I have a 2005 B6 passat 140 sport currently has 81k and was think for the future i would really like the peace of mind that the oil pump isnt going to kick the bucket snd leave me needing an engine, i believe my engine is running the chain driven oil pump, i seen a highline passat up for breaking and was thinking about taking the oil pump out of the CR engine as i heard they are more reliable, can anyone confirm this or has anyone upgraded the oil pump? I would love to hear about some stories about replacing them?
  2. Re: BKP 2.0tdi oil pump replaced with a CR oil pump
    May 2012
    Everywhere
    308 Post(s)
    All CR will be gear driven but some still have an inferior 77mm hex key drive , even when 100mm the balancer shaft keyway still isn't hexagonal or hardened .
  3. Re: BKP 2.0tdi oil pump replaced with a CR oil pump
    Mar 2016
    Well would the CR oil pump have benefits over a 1.9 rep pump and would the CR fit straight on to my engine?
  4. Re: BKP 2.0tdi oil pump replaced with a CR oil pump
    May 2012
    Everywhere
    308 Post(s)
    I doubt it as KMB Parts Direct list PD and CR modified and remanufactured balancer shafts as separate kits .
  5. Re: BKP 2.0tdi oil pump replaced with a CR oil pump
    May 2016
    Pretoria
    Not sure about the BKP motors or the CR but am familiar with the balanced oil pump as the 2.0tfsi has the same pump.
    The BKD motor 2.0tdi 16v does not have that over complicated oil pump but a mere rotary oil pump, small, trust worthy with great pressure.
    This oil pump do fit on the models with the balanced pump, how ever I believe you need to change the chain gear on the crankshaft and the chain. Further than that it's a bolt on.
    They claim you'll have a little more vibration om the motor but it's hardly noticeable.
    Alot cheaper, more reliable, less issues.
    Mine give me around 4.8bar pressure on 2000rpm when hot so pressure are more than enough as the BKD min requirement are 2bar at 2000rpm
    Sent from my E6553 using Tapatalk
  1. Replies: 301
    Last Post: 07-08-2017, 11:45 PM
  2. Please Help Passat 2.0 tdi bkp oil pump balancer shaft?
    By johnbatman520 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-04-2016, 06:04 AM
  3. BKP Oil pump repair kit - preventative
    By steve_v1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-01-2016, 11:20 PM
  4. Question 2.0 TDI 140 BKP Engine and Oil Pump failure
    By spako in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-01-2016, 10:55 PM
  5. Question BKP oil pump fail recon/compatible engine anyone?
    By mehmiller in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-12-2013, 01:16 AM
