Thread: 1.9 TDI 105 BHP - Engine stuttering during start up, but only when warm!
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: 1.9 TDI 105 BHP - Engine stuttering during start up, but only when warm!
    Jul 2007
    glasgow
    35 Post(s)
    first thing is check the battery for broken cell or cells
    second is check the voltage of the alternator output to make sure the battery is getting a full charge, anything over 14 volts
  2. Re: 1.9 TDI 105 BHP - Engine stuttering during start up, but only when warm!
    Mar 2016
    doo dee doo
    Quote Originally Posted by niall campbell View Post
    I have a multimeter, it wasn't an expensive one so I'm not sure if I could measure the output voltage with that?
    What about broken battery cells? Can I check that myself?
  3. Re: 1.9 TDI 105 BHP - Engine stuttering during start up, but only when warm!
    Mar 2016
    doo dee doo
    So today I hooked my car up to a diagnostic program I bought on ebay for dirt cheap, not sure how good it is, but it's a VAG-KKL and the software is labeled as VAG COM Release 409-1. And the only address I was able to get information out was 01 - Engine, and it found this fault code:
    To me it seems like my fuel temperature sensor is broken, am I right with this? Could this be the problem to my engine stuttering during ignition when warm? Also, why am I only able to read 01 and no other stuff?
  4. Re: 1.9 TDI 105 BHP - Engine stuttering during start up, but only when warm!
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Looks like the fuel temp sensor is a good place to start.
    I think you are only seeing OBD II (engine) data with that cable, as your car uses CAN data network I don't think that cable will allow communication with other modules.
  5. Re: 1.9 TDI 105 BHP - Engine stuttering during start up, but only when warm!
    Mar 2016
    doo dee doo
    I was wondering if you'd be so kind to help me figure out the exact cable I need to buy on ebay that would work for my car? I currently own the exact same one as here:
    VAG com 409 1 ELM327 OBD 2 II USB Cable Car Diagnostic Scanner Tool for Audi VW | eBay
    Thank you very much in advance
    PS: My car is a Golf MK5, 1.9 TDI, 105 BHP / 77 kW, BKC Engine, 7th / 8th VIN number: "1J".
  6. Re: 1.9 TDI 105 BHP - Engine stuttering during start up, but only when warm!
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    You need the vcds cable from Ross tech.
  7. Re: 1.9 TDI 105 BHP - Engine stuttering during start up, but only when warm!
    #17
    Sep 2008
    Isleworth, West London
    I fixed my warm start issue with a new battery. (same engine as yours). The starter needs to spin a bit faster when starting from warm. My old battery seemed fine, voltage was ok and alternator was ok. But a new battery cured the problem.
  8. Re: 1.9 TDI 105 BHP - Engine stuttering during start up, but only when warm!
    #18
    Jul 2007
    glasgow
    35 Post(s)
    the fuel temp sender unit, you could simply disconnect it to see if indeed it is away
    Do your self a favour and buy from VW . It might be updated even though its a sender unit, some of the coolant temp sender units have been updated due to faults
    It wont cost much more to get a genuine one, its the muckabout factor of fitting a duff aftermarket and having problems with it.
  9. Re: 1.9 TDI 105 BHP - Engine stuttering during start up, but only when warm!
    #19
    Mar 2016
    doo dee doo
    So I fixed my warm start issue.
    It turned out to be the starter, had it fixed and now the engine fires on easily even when warm. Thank you all for your input!
  1. Replies: 0
    Last Post: 17-11-2013, 10:51 PM
  2. Passat 1.9 tdi 130 bhp 2002 revving up after engine warm and standing??
    By BICCUS1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-09-2013, 02:58 PM
  3. Please Help 04 TDI S 1.9 105 bhp - Violent hot start
    By Drifterwanab in forum Golf MK5 - 2004 - 2009
    Last Post: 21-10-2012, 11:08 PM
  4. TDI 105 (BKC Engine) cold start trouble VIDEO2 HELP!!
    By andwat in forum Golf MK5 - 2004 - 2009
    Last Post: 06-03-2012, 05:41 PM
  5. TDI 105 (BKC Engine) cold start trouble VIDEO
    Last Post: 29-02-2012, 10:43 PM
