Thread: Vacuum Pump Leaking Oil. What does this mean??
  1. Vacuum Pump Leaking Oil. What does this mean??
    Dec 2006
    I have an A4 1998 2.5Tdi V6 and it has an oil leak that has finally been traced to the vacuum pump. The garage are have difficulties trying to seal it. What is the vacuum pump? Is it anything to do with the Turbo? Thanks
  2. Re: Vacuum Pump Leaking Oil. What does this mean??
    134 Post(s)
    2009 Post(s)
    The vacuum pump provides vacuum for the brake servo and also for the turbo and EGR which need vacuum for their control systems.
  3. Re: Vacuum Pump Leaking Oil. What does this mean??
    Dec 2006
    Thanks Crasher. So it can leak oil? How much would it cost to replace do you know? Thanks again
  4. Re: Vacuum Pump Leaking Oil. What does this mean??
    134 Post(s)
    2009 Post(s)
    The pump is part number 059 145 100 B (check part number before ordering) and costs £218.14 inc. VAT. They are tight against the bulkhead so awkward to replace but it should only take about an hour. It may be that the leak is just the rubber “O” ring and this is separately replaceable, 059 145 117 £5.01.
  5. Re: Vacuum Pump Leaking Oil. What does this mean??
    Dec 2006
    Thanks Crasher, I will suggest this.
  1. Vacuum Hose
    By mo_schino24 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 17-08-2007, 11:44 AM
  2. vacuum reservoir !!!!
    By philglasgow in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-04-2007, 09:15 AM
  3. Vacuum leak
    By andrewaudi in forum 80 - 90
    Last Post: 11-04-2007, 06:53 PM
  4. electric vacuum pump
    By gaz238 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-03-2007, 04:45 PM
  5. vacuum leak
    By gaz238 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-03-2007, 02:17 PM
