Thread: Fuse box location
  1. Fuse box location
    Hey guys
    UK spec 1.6 tdi se mk7 golf. Can't find fuse box inside car. I want hard wire dash cam. Owners manual says it's in glove box but can't see it. Do I need remove CD player?
    Sent from my SM-G920F using Tapatalk
  2. Re: Fuse box location
    Nov 2014
    North West
    Quote Originally Posted by bakili View Post
    Hey guys
    There is a Fuse box behind the glove box, drop the glove box lid down and there are two release catches (looks like small raised section on the left and right of the inside top edge. You have to push the raised section up quite hard and it will release a plastic catch on the glove box, it's a bit tricky do one at a time, also note there is a trigger mechanism for the internal glove box light which will click out when you lower the lid section. It's pretty straight forward just take time to note which way the mechanism for the light slides back into the unit on the left hand side of the box.
    Once the lid section is dropped you can see the internal fuse box.
    Golf 1.4 Tsi GT 150PS DSG
  3. Re: Fuse box location
    Dec 2010
    Worcs, UK
    As above, found a photo I posted elsewhere.
  4. Re: Fuse box location
    Nov 2014
    North West
    Good photos, I'm also going to install dash cam, I'm presuming the F40 fuse is the one to use a piggy back fuse to connect so the dash cam comes on with ignition on? The small side panel next to the glove box contains a key switch for the air bag, is it safe to prise this panel off for routing wires from the dash cam?
  5. Re: Fuse box location
    Jun 2014
    Norwich, Norfolk, UK
    Quote Originally Posted by Ian91 View Post
    I would like to re open this post....could anyone answer this as I want to hardwire a dashcam. Thanks
  6. Re: Fuse box location
    Yes it's safe to prise panel off with airbag switch, just make sure you don't disconnect it
  7. Re: Fuse box location
    Jun 2014
    What happens if it gets disconnected accidentally?
    Sent from my SM-G935F using Tapatalk
  8. Re: Fuse box location
    Will bring air bag light on, which will require diagnostic tool to reset.
  1. Passat CC B6 Fuse Box Location and access
    By retro in forum Passat CC
    Last Post: 24-08-2013, 01:17 PM
  2. location of fuse box(s)??
    By dreddfan in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-07-2012, 08:41 AM
  3. 2001 Polo Gti fuse box location?
    By James-NZ in forum Polo - Derby - Lupo - Fox
    Last Post: 25-06-2009, 02:52 AM
  4. a4 tdi 1999 fuse box location?
    By rob1976 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-10-2008, 07:33 PM
  5. help, Location of internal fuse box
    By Don_passat98 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-02-2008, 09:26 AM
