Thread: Aux belt tensioner bracket bolt keeps snapping - why? Help?
  1. Aux belt tensioner bracket bolt keeps snapping - why? Help?
    Mar 2016
    Nottingham
    Hi, I have a AUDI A4 B6 2.5tdi AKE engine,
    The problem that I have is that the bracket that holds the aux belt tensioner onto the engine keeps snapping at pivot point? can anyone tell me why? 2nd time this has happened in 1 year?
    This time I am going to replace tensioner pulley, bolt, bracket pivot piston/sleeve and bushes {that are fixed into the housing of the bracket as they seemed worn and causing slight play in the assembly}
    Can anyone shed some light as to what actually goes on in order for this bolt to give? Its a small bolt, torx bolt, that holds the 'spring' assembly onto the engine.
    Thanks in advance, if I've explained this badly please say and il try to be more clear
    Thanks guys!!
    Carl
  2. Re: Aux belt tensioner bracket bolt keeps snapping....WHY!? HELLPP?
    Jul 2007
    somerset
    8 Post(s)
    Is your alternator pulley one way clutch assy working ok or has it seized up. Does the tensioner jump around a lot when the engine is ticking over, if yes, your alternator pulley needs replacing.
  3. Re: Aux belt tensioner bracket bolt keeps snapping....WHY!? HELLPP?
    Mar 2016
    Nottingham
    Hi, thanks for your suggestion! I didn't think the 2.5 AKE V6 engine had clutched alternator pulleys? Or do they? 53 plate?
    The alternator pulley seems good, free moving and no strange noises? it did 15k from the first time the bolt had sheared until this time, so im assuming if the alternator had failed somewhat, the alternator wouldn't last another 15k before the problem occurring again?
    Thanks for your reply!
    carl
  1. Question Aux belt tensioner bracket bolt keeps snapping - why? Help
    By clowntitz in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-07-2016, 07:06 PM
  2. Aux belt tensioner bolt snapping
    By jgreenwell in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-05-2012, 08:07 PM
  3. Question MK5 golf tdi cam belt tensioner bolt snapping
    By dcrossin in forum New Member Introductions
    Last Post: 13-01-2010, 05:06 AM
  4. Cam Belt Tensioner Mounting Bolt
    By steve1976 in forum Golf MK3 - 1993 - 1999
    Last Post: 02-12-2009, 06:50 PM
  5. Feedback re Polo Aux Belt snapping
    By Deeps in forum Polo - Derby - Lupo - Fox
    Last Post: 14-10-2008, 09:44 PM
