Thread: Esp light on after flat battery.
Results 11 to 20 of 21
  1. Re: Esp light on after flat battery.
    Oct 2015
    GB
    Perhaps your right, have you rang a vw dealer tech for advise?, my local dealer tech is quite helpful and helps me out where he can.
    Vcds lite with an upgrade purchase may help if you call vag com they may help you out also.
    Sent from my SM-A300FU using Tapatalk
  2. Re: Esp light on after flat battery.
    Feb 2007
    No, haven't spoken to anyone else yet. Thought I'd ask here first.
  3. Re: Esp light on after flat battery.
    Oct 2015
    GB
    Vcds lite is free to download but I did think it will not do modules/canbus so an upgrade will more than likely be needed.
    Also try posting your engine code on here, as this may only be common on your year engine and others may know a little more.
  4. Re: Esp light on after flat battery.
    Jan 2011
    East Kent
    If I remember correctly, vcds lite won't work on this year of car.
    The fault codes clearly say that they have lost their basic settings so you must be right with your research. This is backed up by looking up your fault codes here: Category:Fault Codes - Ross-Tech Wiki which says that it needs adapting to get the basic settings again.
    If you don't want to take it to an independent specialist garage (who should have vcds or similar) then you could look at the vcds forum map to see if there is a forum member near to you who can help.
    When the battery gets very low, I believe that these cars go into deep sleep to keep this stuff going, so the battery must have got really low.
    Previous: 2005 A3 1.9tdi SE
    2009 Audi A3 2.0tdi 138bhp SE
  5. Re: Esp light on after flat battery.
    Feb 2007
    I know people don't like cheap eBay versions of VCDS on here but a mate gave me a copy he didn't need and it worked a treat. No more ESP light on.
  6. Re: Esp light on after flat battery.
    Dec 2007
    8 Post(s)
    Did it just clear the fault codes.or had you to do any resetting e.t.c
    Its good that you got sorted.
  7. Re: Esp light on after flat battery.
    #17
    Feb 2007
    I had to re-enter the basic settings for the steering, brakes etc .
    Took a little while working out how to use the software but searching Google on how to do it brings up quite a bit of info.
  8. Re: Esp light on after flat battery.
    #18
    Aug 2008
    north hampshire
    The car has to re set all of its parameters. When you reconnect the battery, drive in a straight line and then full lock left and full lock right and that syncs the cars limit. Mine went and luckily I knew a guy at Southampton Audi and he showed me the fault codes his diagnostics picked up and it was things like steering position sensor, brake position sensor and some other sensors to do with suspension! He drove it straight, full lock either way and sorted!
  9. Re: Esp light on after flat battery.
    #19
    Feb 2007
    Driving mine didn't sort it mate ! Only way to sort it is using VCDS to reprogram the basic settings.
  10. Re: Esp light on after flat battery.
    #20
    Feb 2021
    Swindon
    Hi I have the same problem with my mk5 golf, how do I find out the codes needed?
  1. airbag light on after flat battery
    By neilstouran in forum Touran - Sharan - Caravelle
    Last Post: 28-12-2013, 10:28 PM
  2. Flat battery - esp fault ???
    By RJWOOD in forum Golf MK6 - 2009 - 2013
    Last Post: 22-06-2013, 08:21 AM
  3. Please Help battery flat so i jumped the car red power steering light on wont come off
    By j1981 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-10-2012, 07:21 PM
  4. Audi 2.5 TDI heater plug light and flat battery
    By scootermap in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-02-2010, 12:35 AM
  5. Please Help Passat 2.0S 2002 Brake Lights and Flat Battery with intermittent ESP / ABS warning light
    By tweever in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-10-2009, 01:50 PM
