Thread: 2.0 TDI unable to connect through OBD
  1. 2.0 TDI unable to connect through OBD
    Sep 2007
    Hi, had an engine light come up yesterday and read the code using a generic scan tool (P0299 Turbo Underboost). No problem.
    Today wanted to confirm the error after another light and I cannot connect through OBD. I have power to the reader, same tool used as yesterday. Car still works as before.
    Car is all standard, stock radio.
    I'm not able to get a VCDS connected up today is there anything obvious I should be looking for right now as to why this is no longer working?
  2. Re: 2.0 TDI unable to connect through OBD
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    I assume its not a genuine VCDS cable? If it is then register the cable online VCDS Dongle Registration then you can join Ross-Tech forum and ask about this problem.
    VAG Error Code: 16683/000665/11226/15343/5671/7384
    EOBD II Error Code: P0299
    Fault Location:
    Boost Pressure Regulation - Control Range Not Reached/Low Boost
    Possible Cause:
    Malfunction Indicator Lamp (MIL)(K83) active.
    Reduced Power Output.
    Limp Mode.
    Hoses/Pipes incorrectly connected, disconnected or leaking.
    Charger Pressure Control defective.
    Turbocharger faulty.
    Diverter Valve faulty.
    Possible Solutions:
    Check Hoses/Pipes to/between Components.
    Check/Clean/Replace Charge Pressure Control.
    Check Turbocharger.
    Check Diverter Valve.
    Special Notes:
    When found in 2.0l
    TFSI:
    Check Boost Pressure Control Valve (N249), for cracked rubber
    diaphragm. A new/optimized Valve is available under Part # 06H-145-710-D (or newer).
    Rest of World (RoW) vehicles see: Technical Product Information (TPI) 2016331 for details.
    North American Region (NAR) vehicles see: Technical Service Bulletin (TSB) 01-07-70 or 2013392 for details.
    When stored in conjunction with misfire codes and/or fuel trim faults see the notes associated with the following faults regarding Positive Crankcase Ventilation (PCV)
    failure: Crankcase
    Breather Valve
    If the Turbocharger is faulty due to mechanical/internal problems or the exhaust system is restricted (typically the Catalyst) this fault may be the end result.
    When found in VW Golf/Jetta (1K): 2.0l CR-TDI (CBEA/CJAA):
    Verify the mechanical part of the Exhaust Pressure Flap Control Module (J883) is not seized or binding.
    When found in Audi
    A4/S4/RS4/Cabriolet (8K):
    2.0l (CAEB):
    See Technical Product Information (TPI) 2031245/6 - turbocharger excessive waste-gate play.
    As taken from my new EOBD II Error Codes
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  3. Re: 2.0 TDI unable to connect through OBD
    Sep 2007
    No just a generic code reader. Thanks I did see what the code was for and it will now be going back to the dealer. I'm just concerned that the port no longer functions
  4. Re: 2.0 TDI unable to connect through OBD
    Sep 2009
    12 Post(s)
    Generic code readers are hit and miss you need to get a genuine VCDS cable.
  5. Re: 2.0 TDI unable to connect through OBD
    Sep 2007
    I've never had a problem in the past are newer cars more fussy?
    The garages in my area all use the Snap On readers. That connected without any problem and pointed towards the VNT actuator. Fixed.
  1. Question 2008 A3 2.0 TDi Quattro - OBD 2 or VCDS
    By audikid in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 11-06-2015, 08:05 AM
  2. How to read OBD-II diagnostics on 1999 TDi
    By nickrs in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 28-02-2015, 09:09 PM
  3. Please Help VCDS wont connect to my car anymore but will connect to my wifes
    By ads1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-12-2014, 01:35 AM
  4. OBD-II/EOBD Code Reader for VW GOLF Mk 6 2009 2.0L TDi
    By warrtydog in forum Golf MK6 - 2009 - 2013
    Last Post: 16-03-2014, 04:18 AM
  5. Question I need to replace my cats on my 2.4, how do I tell if I need OBD or non-OBD?
    By Carpie in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-01-2011, 09:39 PM
