Thread: Whats this part? - making a popping sound
Results 1 to 10 of 34
  1. Whats this part? - making a popping sound
    Jun 2013
    Ireland
    Just after noticing a funny noise coming from my engine, 1.9 AVB
    I took off the engine cover and theres a popping clonking noise coming from this part when the car is idling or if I just bearly tip the accelerator!!
    any ideas?
  2. Re: Whats this part? - making a popping sound
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    That's the exhaust gas recirculation valve, actuated by the diaphragm which is the round flying saucer on top and the anti shudder valve actuated by the smaller black diaphragm and lever on the side. Don't know what is making the popping noise, maybe the egr diaphragm is split. It looks pretty dirty and will likely be badly choked up inside. Do you have the orange check engine light on the dash?
  3. Re: Whats this part? - making a popping sound
    Jun 2013
    Ireland
    thanks Rob,
    no lights on the dash but I had another listen and it sounds like a diaphragm popping,
    ah well... back to the garage!!
  4. Re: Whats this part? - making a popping sound
    Jun 2013
    Ireland
    Actually the small rubber pipe to the left of the photo is badly worn down from the engine cover.... could be drawing air.?
  5. Re: Whats this part? - making a popping sound
    Jun 2013
    Ireland
    so the car is going back to garage for inspection... suspect a new EGR is needed,
  6. Re: Whats this part? - making a popping sound
    Nov 2010
    104 Post(s)
    well spotted kop77! that's not the original hose material either. It might also be the N18 EGR solenoid valve ( think it's that from memory) playing up giving the popping sound at the actuator.
    I had to change my egr valve last year after the diaphragm split but I got the 'check emissions' up on the dash. The inlet manifold was pretty gummed up as well so I took it off and cleaned, doubt your garage will do that though out of the goodness of their hearts though.
    Easy way to test the diaphragm is pull the hose off and suck on the little metal pipe, you shouldn't be able to draw anything through.
  1. Question Popping sound, front of the car.
    By tomas_v in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-05-2014, 04:10 PM
  2. popping sound after subframe removal
    By Shahzaib in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 24-01-2014, 12:16 AM
  3. audi a6 2.0 tdi making horrific clattering sound when starting
    By deano 75 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-04-2013, 08:57 PM
  4. Battery replacement - starter motor making sound
    By jalz in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 16-01-2012, 03:46 PM
  5. New Stereo Making Awful Sound (video attached)
    By ali_a4_avant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-08-2009, 06:50 PM
