Thread: 2010 Passat Wagon B6: How to remove plenum cover under windshield?
Results 1 to 8 of 8
  1. 2010 Passat Wagon B6: How to remove plenum cover under windshield?
    Feb 2016
    Georgia
    I have a 2010 Passat Wagon and I would like to remove the plenum cover from under the windshield so that I can clean the debris that's accumulated under the plenum. I see that I need to remove the wipers and the four retaining clips. However, my question is relating to the actual removing of the plenum. The plenum looks like it is attached to the windshield base. Is this just a compression fit channel that I can simply pull the plenum away from the windshield to remove? Is the plenum held to the windshield by an adhesive?
  2. Re: 2010 Passat Wagon B6: How to remove plenum cover under windshield?
    Feb 2016
    Georgia
    I think I found an appropriate plenum removal guide: APR - High Performance Development for Audi, VW and Porsche Vehicles.
  3. Re: 2010 Passat Wagon B6: How to remove plenum cover under windshield?
    Jul 2007
    glasgow
    35 Post(s)
    undo the window wipers bolts and prise off wipe wipers
    Lift the plastic cover at the engine end , and it should pop the cover at the widscreen
    Shine torch in plenum and look for water , if any water then look or prod for drain cover. Get a garden hose and try and wash all the rubbish out, without getting water in any electric boxes.
    I take the rubber drain covers out, as they tend to trap the rubbish
    Going by your pictures, the leaves and needle things will be choking up
  4. Re: 2010 Passat Wagon B6: How to remove plenum cover under windshield?
    Feb 2016
    Georgia
    Hello niall,
    Thank you for the response. I'll clean under the plenum this weekend when the car is back at my house and post the findings.
  5. Re: 2010 Passat Wagon B6: How to remove plenum cover under windshield?
    Jul 2007
    glasgow
    35 Post(s)
    it just wont be leaves and pine needles choking it, dust and grime is just as bad , that's why gently hosing the area out will clear the area properly, you will see stuff jammed under pipes etc
    One hint is after taking the nuts off, lift up wiper blade off windscreen and rock it back and forth with two hands to snap up the wiper arm. It will be tight around the thread area. Its actually easier to do than describe it.
    Also look at youtube for similar cars, or A4 . The rubber pipes are in the middle, prodding with long screw drivers can clear it
  6. Re: 2010 Passat Wagon B6: How to remove plenum cover under windshield?
    Jan 2020
    uk
  7. Re: 2010 Passat Wagon B6: How to remove plenum cover under windshield?
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by carexpert1 View Post
    After nearly 4 years I think he's probably done it by now
    Mad Mitch
  8. Re: 2010 Passat Wagon B6: How to remove plenum cover under windshield?
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Quote Originally Posted by DMitch16 View Post
    They can take a while to get off, but perhaps not that long. I cheap wiper puller is handy for simplifying the job IMHO.
  1. Replies: 8
    Last Post: 17-02-2016, 08:27 PM
  2. Question How do you remove persistent smearing on windshield?
    By phil7132 in forum Vehicular windows, Glazing and Tinting
    Last Post: 30-07-2015, 01:01 PM
  3. Plenum chamber cover removal?? Help please.
    By veedub76 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-02-2010, 03:24 PM
  4. Please Help plenum chamber cover
    By arman123 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-04-2009, 10:15 PM
  5. Golf mk4 plenum conduit cover
    By Nixy in forum Golf MK4 - 1999 - 2004
    Last Post: 29-01-2009, 07:43 PM
