Thread: A6 2.7 TDI white smoke and losing coolant
Results 1 to 10 of 20
  1. A6 2.7 TDI white smoke and losing coolant
    Jul 2015
    Norway, Oslo
    Hello people,
    Last week I noticed some white smoke coming out from underneath the front of the car right after a cold start.
    Didn't think much of it, but today the wife called on her way to the mall. Said the car smoked white, and it smelled like burning oil.
    When she came home she said the car really left behind tons of white smoke in the last km uphill to our house. No smoke after parking, but it really smelled like oil burning all over the place.
    Observations:
    1) Cannot see any liquids leaking underneath the car
    2) Coolant level has dropped significantly. 1cm below the "min" mark. Half a year ago, I know coolant level was just beneath the max mark with warm engine.
    3) VCDS scan says:
    Address 18: Aux. Heat Labels: None
    Part No SW: 4F0 910 105 A HW: 4F0 265 081 L
    Component: Heizgeraet H08 0060
    Revision: C Serial number: 09011480
    Coding: 0000111
    Shop #: WSC 02335 758 00200
    VCID: 1B3531E7DA501BC6611-804E
    2 Faults Found:
    01233 - Engine Coolant Blocking Valve for Heater (N279)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 109
    Mileage: 151651 km
    Time Indication: 0
    Date: 2016.02.01
    Time: 15:53:32
    Freeze Frame:
    Start
    Temperature: 6.0°C
    Temperature: 17.0°C
    01412 - Glow-Plug with Flame Monitoring (Q8)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 131
    Mileage: 151971 km
    Time Indication: 0
    Date: 2016.02.12
    Time: 08:23:03
    Freeze Frame:
    Start
    Temperature: 50.0°C
    Temperature: -48.0°C
    I have read that white smoke and losing coolant equals bad EGR cooler or something?
    Any thoughts?
    Regards,
    cozmo
  2. Re: A6 2.7 TDI white smoke and losing coolant
    Oct 2015
    GB
    You checked the dipstick and oil cap for creamy stuff?
    Is the coolant contaminated?
    Sent from my SM-A300FU using Tapatalk
  3. Re: A6 2.7 TDI white smoke and losing coolant
    Jul 2015
    Norway, Oslo
    Coolant does not seem contaminated. No creamy stuff on cap.
    On each start from stand still, I now leave behind a big white cloud..
  4. Re: A6 2.7 TDI white smoke and losing coolant
    Oct 2015
    GB
    Do a coolant pressure test for leaks
  5. Re: A6 2.7 TDI white smoke and losing coolant
    Jul 2015
    Norway, Oslo
    There is absolutely no coolant underneath the car.
    I just drove 10km. On that tour the coolant level went down by 1.5cm measured on the expansion tank. That is quite a lot. If there really is an external leak - it would show on the ground. But it doesn't.
    Funny thing I went from Swedish to German car cause' I was so tired of these kind of unexpected hickups....Lol..
  6. Re: A6 2.7 TDI white smoke and losing coolant
    Jan 2011
    Stafford, UK
    Quote Originally Posted by cozmo View Post
    I had this happen on another car.
    A big white cloud when starting from cold, but once the car had warmed up it was not too bad at all.
    The problem turned out to be a crack in the cylinder head.
    When it was standing cold, coolant was seeping into one of the cylinders, then when starting up it turned to steam.
    It could also be your head gasket.
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  7. Re: A6 2.7 TDI white smoke and losing coolant
    Jul 2015
    Norway, Oslo
    If it really is cracked in the cylinder head, this will be my first and last Audi. That should not happen with a 9 year old car.
    The smoking is there both when warm and cold now. Symptoms tell me head gasket. If so, not impressive at all. This is supposed to be a premium car with excellent build quality.
  8. Re: A6 2.7 TDI white smoke and losing coolant
    Oct 2015
    GB
    Cars can be a bag full of nerves when things go wrong so the best thing to do is have so checks done, I. E pressure test and compression test etc etc.
    A cracked head is not impossible but really only occors on cast iron heads,
    Head gasket, again maybe.
    You may get lucky and all it is a pressure leak which is hitting the exhaust, so you won't always see it.
  9. Re: A6 2.7 TDI white smoke and losing coolant
    Jan 2011
    Stafford, UK
    Quote Originally Posted by grant19841 View Post
    My cracked cylinder head was aluminium (3 year old Daihatsu)
  10. Re: A6 2.7 TDI white smoke and losing coolant
    Oct 2015
    GB
    Daihatsu, says it all mate thin gauge Crap lol soz
  1. A6 1.9 TDI losing coolant
    By Rudidudi in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-12-2015, 01:52 PM
  2. '04 2.0 TDI smoking (blue/white) losing coolant and oil :(
    By danswift in forum Touran - Sharan - Caravelle
    Last Post: 11-01-2015, 07:35 PM
  3. Please Help Drinking Coolant / White Smoke
    By abrafl in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-10-2014, 07:21 PM
  4. Question White Smoke and Coolant Alert Light
    By jared09 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-09-2014, 11:50 AM
  5. Question White smoke after coolant drain and refill
    By happydan in forum A8 - S8 - V8
    Last Post: 15-07-2013, 09:15 AM
