Thread: Once again, Audi runs cold despite changing stat & sensor. Fed up.
  1. Once again, Audi runs cold despite changing stat & sensor. Fed up.
    Jan 2009
    Hi we have a 2003 1.9TDi B6 model. This car seems to be plagued by low temperature indication.
    Previously to resolve this, we've changed the temp sensor which worked for a while, then eventually (after some months) went back to showing cold again. At that point, we changed the water thermostat after which the temp then showed 85 degrees during normal operation. This worked for a few months but now again the temp is showing cold again.
    Current symptoms-
    Temp gauge does not rise much above cold at any point
    Heater works fine
    Should we replace the sensor again or the stat (with a genuine Audi part)?
    Or just take a lumphammer to the car and smash it to smithereens, which admittedly won't affect the cars temperature but will warm me up no doubt.
  2. Re: Once again, Audi runs cold despite changing stat & sensor. Fed up.
    chester
    17 Post(s)
    Hold off on the lump hammer,its got to be one or the other,have you got vcds?to check the coolant temp reading going to the ecu,its good practice to always use genuine temp sensors,where did you get the temp sensor from?
    A4 B6,A4B7Quattro,MK4 Golf,MK5Golf gone and well forgotten,MK6Golf.
  3. Re: Once again, Audi runs cold despite changing stat & sensor. Fed up.
    Jul 2015
    Staffs
    46 Post(s)
    If the heater works,normally then the stat is operating correctly.
    It will be either the gauge, sensor or a wiring problem.
    Its hardly a massive problem for a 13 year old car, so lay off the lump hammer!
    Ian
    A4 B6 Avant Nogaro Blue
  4. Re: Once again, Audi runs cold despite changing stat & sensor. Fed up.
    Jan 2009
    Not sure how to check the reading going to ECU, sensor was a cheap one (non genuine). Fitted about 2 or 3 years ago but this problem has resurfaced only recently. Maybe one of these would be better? -
    http://www.ebay.co.uk/itm/COOLANT-TE...oAAOxyzTJTjvEF
  5. Re: Once again, Audi runs cold despite changing stat & sensor. Fed up.
    Apr 2015
    United Kingdom
    My 1.9Tdi temp gauge was below half when hot, so when I had my timing belt changed I also had the thermostat and temp sensor changed for genuine parts. It ran fine for a week and then the temp gauge showed the same about 85 when hot and got worse. I had the garage look at it and they then changed the thermostat and sensor again for genuine. it's been working great since.
    I've read somewhere on here I think that when you change the thermostat you might as well change the temp sensor, and use genuine for both.
    Best of luck!
    Audi B6 A4 Avant 1.9 Tdi 130 Quattro
  6. Re: Once again, Audi runs cold despite changing stat & sensor. Fed up.
    Jan 2009
    Birmingham
    36 Post(s)
    I had this problem a few years ago temp sensor and stat was changed for genuine one stat was done by dealer when cam belt was done the sensor I changed my self still after I got it back from dealer the temp would not sit at 90 always about 85 ish so went back to dealer saying the cars overcooling they checked it all out and said you need to replace the radiator I wasnt having any of that and refused to have them change the rad got the car home at had a look myself I bought a new genuine stat with oring took the stat off I had a good look at the housing were the stat sits the two tabs on the housing were not there this is were the stat turns and locks into housing so bought a new housing from tps changed it over put it all back together at it has sat on 90 till then problem sorted I think with out the tabs the stat does not seat properly with the engine so always coolant seeping through over cooling engine
  7. Re: Once again, Audi runs cold despite changing stat & sensor. Fed up.
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    I dont want to come across rude, but we have all said on countless previous sender related issues, dont ponce about using cheap replacement items 2 or 3 times, just go genuine at first and do the job once,
    Again not being clever or rude, good luck
    Stuart
    A6 2.4 SE (2000)S3 1.8T (2001)80 Coupe 2.3 (1991)
    A3 1.8T sport (1997)A4 3.0 QST (2002)
    80 Coupe 2.6S (1995)A4 Cab 2.4 sport (2002) Another 2.6 '95 coupe in byzanz purple
    '88 type 89 90 saloon kv 5 pot A4 1.8T 2001
  1. GT Stat.Audi Remote Stat
    By HAWKS in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-05-2013, 05:42 PM
  2. Changing thermo stat passat 1.9tdi s reg
    By carlhutch22 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-03-2010, 10:57 PM
  3. 1996 A6 2.6 runs cold
    By 01alam in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 09-11-2009, 09:39 PM
  4. Question Runs rough when cold
    By Maz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-03-2009, 11:21 AM
  5. rad, stat & heater probs help needed!
    By PinkMinx in forum Golf MK2 - 1984 - 1992
    Last Post: 26-11-2007, 03:10 PM
