Thread: Rumble sound from front left, no one can find issues
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. Rumble sound from front left, no one can find issues
    warp_speed Guest
    I've got a 2011 S4 with 48k miles on the clock and seem to have a bad rumble sounds coming from my passenger front.
    It starts off in the morning as a couple of clicks when coming off my drive way, but when you drive the car over some rough roads at a slow speed the rumble gets worse until it sounds like a broken spring.
    My cars got the Audi drive select which lets your adjust the shock absorber damping rates, when it’s on dynamic mode the noise gets worse even quicker.
    Been to my Audi dealer 3 times with the issue and they say there is nothing they can see suspension wise, I'm beginning to think it’s either a dodgy shock/strut or a bad wheel bearing. Anyone got any ideas?
  2. Re: Rumble sound from front left, no one can find issues
    Nov 2013
    Cumbria
    Have you rotated the wheels - may be a dodgy alloy or wheel ? Have you checked the brakes - perhaps something has come loose ?
    Audi A6 C7 Avant - quattro, black edition sline - 3.0 BiTDi
    Audi A3 8PA - quattro, black edition sline - 2.0T
    Audi A4 B8 Avant SLine - 3.2 V6 Quattro - now sold
    Audi A3 8P - 2.0T Quattro - sold
    Audi A4 B7 Avant - 2.0T - heap of junk, now gone!
  3. Re: Rumble sound from front left, no one can find issues
    warp_speed Guest
    Quote Originally Posted by b206 View Post
    Alloy wheels have been checked and brakes have been replaced, double checked as well.
  4. Re: Rumble sound from front left, no one can find issues
    Dec 2007
    8 Post(s)
    The clicks that you hear while coming off drive, are the wheels in straight position or on part/full lock
    Maybe there is a broken spring which is hard to see.
  5. Re: Rumble sound from front left, no one can find issues
    warp_speed Guest
    The knocks are worse when on a lock, but there is knocking when the wheels are straight. Coming off a high curb on full lock starts the noise off.
  6. Re: Rumble sound from front left, no one can find issues
    Dec 2007
    8 Post(s)
    Would be best to take it elsewhere to get second opinion,especially as you can replicate the problem to assist them.
    As you say possible wheel bearing / cv joint issue
    Is the knocking consistent with wheel revolutions or more with suspension bouncing when coming off high kerbs etc.
  7. Re: Rumble sound from front left, no one can find issues
    warp_speed Guest
    Quote Originally Posted by micheal balbrig View Post
    suspension bouncing. Sharp speed bumps and coming off a kurb starts it off and then every small bump on the road causes a clunk. Will try another dealership for a second opinion
  8. Re: Rumble sound from front left, no one can find issues
    Dec 2007
    8 Post(s)
    Seems to point more now to suspension problem
  9. Re: Rumble sound from front left, no one can find issues
    Jan 2010
    southport
    Drive shaft CV joints click when on a lock when they first start to go.Have you tried in a car park, starting off slowly an turn left lock driving in a circle, then right lock.
    2000 2.5TDI Quattro 173,000miles, just run in...Sold
    2006 TT 3.2 Quattro 40,000miles
    2005 A6 Avant 3.0TDI Quattro
  10. Re: Rumble sound from front left, no one can find issues
    warp_speed Guest
    Quote Originally Posted by HAWKS View Post
    Tried that no noise, unless I drive into a pot hole and it clunks. Got it booked in today to another audi dealership to see if they can find the issue. Master tech think it sounds like an upper arm but sure the first dealership would have seen it.
  1. Question Metallic crunching sound from front left
    By frr8dog in forum A8 - S8 - V8
    Last Post: 13-05-2013, 07:14 PM
  2. Please Help Sharan 4motion TDI with rumble sound in the rear
    By dekleinebach in forum Touran - Sharan - Caravelle
    Last Post: 06-09-2010, 02:09 PM
  3. Passat 03 weird sound when I turn left
    By gun_em_down in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-02-2009, 05:54 PM
  4. A loud growling sound from front left?
    By kojack3175 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-08-2007, 01:19 PM
  5. Front wheel Rumble
    By scousefly in forum Passat - Archive Topics
    Last Post: 28-04-2007, 06:36 PM
