Thread: Vw polo 01044 fault code
  1. Vw polo 01044 fault code
    Apr 2014
    Hi vw polo with 01044 - Control Module Incorrectly Coded there has been fitted a rsn510 any one know the code it should be changed to the code atm is 002300 any help would be great many thanks
  2. Re: Vw polo 01044 fault code
    133 Post(s)
    1986 Post(s)
    When using full registered VCDS there are long coding help tables that should allow you to code in an RNS510. This code is in the head unit itself isn't it?
  3. Re: Vw polo 01044 fault code
    Apr 2014
    Hi I have the full registered vcds. I tried looking in the long coding but can't seem to find what to do I have a full scan of the car I will post up now
  4. Vw polo 01044 fault code
    Apr 2014
    Code:
    Saturday,06,February,2016,13:09:35:28155
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
    VCDS Version: 15.7.3.0
    Data version: 20151216
    Ross-Tech: Home
    VIN: WVWZZZ6RZCU043165   License Plate: GF12PTZ
    Mileage: 50630km-31460mi   Repair Order:
    Chassis Type: 6R (6N0)
    Scan: 01 03 08 09 15 17 19 25 2E 37 44 56
    VIN: WVWZZZ6RZCU043165   Mileage: 50630km-31460miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    37-Navigation -- Status: Not registered 0011
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine (J623-CGPB)       Labels: 03E-906-019-CGP.clb
       Part No SW: 03E 906 019 M    HW: 03E 906 019 B
       Component: SIMOS11.1     H03 9487
       Revision: --H03---    Serial number:
       Coding: 00110016000400080000
       Shop #: WSC 31414 790 50316
       ASAM Dataset: EV_ECM12MPI02103E906019M 001008
       ROD: EV_ECM12MPI02103E906019A.rod
       VCID: 2E54A92A717ABE4ED3-807A
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
       Part No SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
       Component: ESP8.2i front H05 0002
       Revision: --------
       Coding: 230224E3217100B5C42624E884D600801300
       Shop #: WSC 31414 790 31414
       VCID: 00082792976EF83E71-8054
    Address 08: Auto HVAC (J301)       Labels: None
       Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
       Component: Man AC        H02 0202
       Revision: 0003SH02
       VCID: 397E8A76B03469F676-806C
    Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
       Part No SW: 6R0 937 087 K    HW: 6R0 937 087
       Component: BCM PQ25 H+4  H46 0254
       Revision: BF046001    Serial number: 0434 326110392
       Coding: 24B02BBF08A10000003008002D2B0CD00040410F60060000200000000000
       VCID: 4586F686CCCC1D1602-8010
       Subsystem 1 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  008 1611
       Coding: 18BC30
       Subsystem 2 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  008 1611
       Coding: 08BC30
       Subsystem 3 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
       Component: J388__TSG_HL  008 1611
       Coding: 08BC32
       Subsystem 4 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
       Component: J389__TSG_HR  008 1611
       Coding: 08BC32
    Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10Airbag027 H09 0020
       Revision: --------    Serial number: 003GX010HU1F
       Coding: 003237
       ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
       ROD: EV_AirbaVW10BPAVW250_SE25.rod
       VCID: 4A9CC5BAEDD2F26EEF-801E
       Crash sensor for side airbag; driver side:
       Serial number: 3575HRB405L0T3R85PPC
       Crash sensor for side airbag; front passenger side:
       Serial number: 3585HRB405P0SM2M1H6-
       Crash sensor for side airbag; rear; driver side:
       Serial number: 3515RRB405D0TGJM9HFD
       Crash sensor for side airbag; rear; passenger side:
       Serial number: 3525RRB405V0TQMACOE%
    Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
       Part No SW: 6R0 920 960 H    HW: 6R0 920 960 H
       Component: KOMBI         H03 0505
       Serial number: 00000000000000
       Coding: 440A01
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
       ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
       VCID: 3A7C957ABD3262EE7F-806E
    Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
       Part No SW: 6N0 909 901     HW: 6R0 937 087
       Component: GW-K-CAN TP20 H46 0254
       Revision: BF046001
       Coding: 002300
       VCID: 70E87752A3CEE8BE81-8024
    1 Fault Found:
                000 -  -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 255
                        Time Indication: 0
    Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
       Part No SW: 5K0 953 234     HW: 5K0 953 234
       Component: IMMO          H03 0505
       Serial number:
       Coding: 000000
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
       ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
       VCID: 6ADC653A8D12126ECF-803E
    Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
       Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
       Component: SG EXT.PLAYER H13 0240
       Revision: A1001003    Serial number: 7661325572
       Coding: 010000
       VCID: 295E5A364094D97606-807C
    Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
       Part No SW: 1T0 035 680 D    HW: 1T0 035 680 C
       Component: RNS-MID       H06 4120
       Revision: AB001001    Serial number: VWZ6Z7K4146067
       Coding: 00000400000000000000
       VCID: 2F6AB42E7E70B746D8-807A
       Subsystem 1 - Part No: 1T0 919 859 B
       Component: EU West V11  8117
    4 Faults Found:
    01042 - Control Module; Not Coded
                000 -  -
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 254
                        Reset counter: 169
                        Mileage: 45360 km
                        Time Indication: 0
    00856 - Radio Antenna
                007 - Short to Ground - Intermittent
                 Freeze Frame:
                        Fault Status: 00100111
                        Fault Priority: 5
                        Fault Frequency: 11
                        Reset counter: 177
                        Mileage: 50248 km
                        Time Indication: 0
    01523 - Microphone for Telephone (R38)
                011 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01101011
                        Fault Priority: 5
                        Reset counter: 169
                        Mileage: 45363 km
                        Time Indication: 0
                        Date: 2015.09.02
                        Time: 22:09:03
    01305 - Databus for Infotainment
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 0 km
                        Time Indication: 0
    Address 44: Steering Assist        Labels: 6Q0-423-156.clb
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 11250
       Shop #: WSC 31414
       VCID: 2F6AB42EEA70B746D8-807A
    Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
    4 Faults Found:
                000 -  -
                 Freeze Frame:
                        Fault Priority: 5
                        Reset counter: 169
                        Mileage: 45360 km
                        Time Indication: 0
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 11
                        Reset counter: 177
                        Mileage: 50248 km
                        Time Indication: 0
                011 - Open Circuit
                 Freeze Frame:
                        Fault Priority: 5
                        Reset counter: 169
                        Mileage: 45363 km
                        Time Indication: 0
                        Date: 2015.09.02
                        Time: 22:09:03
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 0 km
                        Time Indication: 0
    End-------------------------(Elapsed Time: 02:29)--------------------------
  5. Re: Vw polo 01044 fault code
    133 Post(s)
    1986 Post(s)
    Go into the CAN section, go to installed equipment and tick the box for navigation, that will deal with the CAN error. The radio coding needs altering to suit the car, the microphone input monitoring needs turning off and it is looking for an infotainment system it does not have. The antenna fault may be that you need an adapter cable.
  6. Re: Vw polo 01044 fault code
    Apr 2014
    Ok thank you for you help how would I go about altering the radio coding
  1. Question Polo 9N Fault Code 17961
    By bartleaj in forum Polo - Derby - Lupo - Fox
    Last Post: 22-04-2013, 08:46 AM
  2. Polo 1.2 - 2005 - Fault Code 16804
    By bigrich1 in forum Polo - Derby - Lupo - Fox
    Last Post: 10-09-2011, 11:22 AM
  3. polo 1.2 2003 fault code 16825 35-10
    By paul1964 in forum Polo - Derby - Lupo - Fox
    Last Post: 24-07-2011, 12:55 PM
  4. Please Help Polo Fault code p0172
    By martin77 in forum Polo - Derby - Lupo - Fox
    Last Post: 15-07-2011, 11:13 AM
  5. How To VW Polo - ABS Fault - 04FC Error Code
    By JPME in forum Polo - Derby - Lupo - Fox
    Last Post: 21-04-2011, 08:40 PM
