Thread: Solid flywheel noise
Results 1 to 10 of 11
  1. Solid flywheel noise
    May 2015
    Aviemore
    Hi ive changed my dual mass flywheel to solid flywheel kit yesterday. But it makes noise like my dual mass flywheel, when it was broken. Is that normal? Advice needed.
    Sent from my GT-I9505 using Tapatalk
  2. Re: Solid flywheel noise
    46 Post(s)
    this is one downside of the solid conversion, it will be noisier than a brand new dmf.
  3. Re: Solid flywheel noise
    May 2015
    Aviemore
    But the noise is only there when clutch is released,
  4. Re: Solid flywheel noise
    Jul 2013
    76 Post(s)
    The release bearing is probably no good.
    If you got the job done at a garage then take it back.
    Dan
    2009/2010 2.0 TDIe SE
  5. Re: Solid flywheel noise
    May 2015
    Aviemore
    Ive suplyed the parts. They might tell that its my part fault.
  6. Re: Solid flywheel noise
    May 2015
    Aviemore
    Ican live with that aslong its not breaking anything.
  7. Re: Solid flywheel noise
    May 2014
    Darlington
    78 Post(s)
    It will be flywheel chatter, it was never designed for a SMF, so you will get this and other issues may appear, and some have complained of gearbox damage after a SMF conversion, think it's down the the vibration that the DMF filters out.
    Nice little aritical on SMF & DMF. https://www.torquecars.com/tuning/dm...d-flywheel.php
    0 2 0
  8. Re: Solid flywheel noise
    May 2015
    Aviemore
    I don't have any vibration, just the noise, when clutch is up. But car drives perfectly fine.
  9. Re: Solid flywheel noise
    May 2015
    Aviemore
    I was searching around the net. That's common for smf.
  10. Re: Solid flywheel noise
    Nov 2015
    Bucks
    I've had solid instead of DM flywheels in the past - they tend to be slightly rattly at idle when sat in neutral specifically. As soon as the clutch is depressed the noise should disappear.
    It's a side effect of reduced weight, there's less damping mass to stop transmission lash / rattle.
    It's nothing to worry about generally but I'd suggest contacting the supplier of the kit to check it's normal if you're not sure :-)
  1. Question Solid flywheel conversion?
    By Seank_84 in forum Golf MK5 - 2004 - 2009
    Last Post: 27-01-2016, 05:44 PM
  2. solid flywheel noise at 2000revs
    By andwat in forum Golf MK5 - 2004 - 2009
    Last Post: 23-12-2013, 11:33 AM
  3. solid flywheel noise at 2000revs
    By andwat in forum Touran - Sharan - Caravelle
    Last Post: 20-05-2012, 09:32 PM
  4. Solid flywheel conversions
    By mikea31.820vt in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 09-02-2011, 04:48 PM
  5. Question Solid Mass Flywheel
    By STONEWALL in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-06-2008, 12:00 AM
