Thread: Glove box??
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Glove box??
    May 2007
    Blackpool
    My glovebox, stopped opening.. must av snapped sumfin.. i just want a new lid and brackets.. any help
    i need a new glove box lid.. any help.
  2. Re: Glove box??
    Mar 2007
    Lancashire
    Funny you should ask about glove box Dub. Opened mine at the weekend and crack! I thought a CD had got caught up and broken but something has broken that supports it. It just drops open when opened, no resisitance, and the light has stopped working.. great!! I love these Audis.
    Another weekend fix. I'm not forking out for a new one. If I get the light working again I will be happy!
  3. Re: Glove box??
    Jul 2007
    You can't get the lid seperately from Audi - I recently bought a glovebox with the CD changer prep - that was £150 retail price from Audi!
  4. Re: Glove box??
    Aug 2007
    Norwich
    Quote Originally Posted by Marco34 View Post
    I had the same sodding thing happen to mine monday. no crack or noise when i opened it apart from the sound of it bouncing as it wasn't damped. Not happy. Light still works though. Have to have a look wk end. Let us know if/how you manage to fix it. I'll do likewise.
    Mellie.
  5. Re: Glove box??
    Aug 2007
    Yes this happend to my car and guess what also to my fathers A4....you can access the switch / plunger mechanism which is behind the plastic panel on the side of the cars dash -
    Open passenger door ( if you have a car handbook it will show you how to open it as if you are replacing fuses LHD) then prise open cover with flat head screwdriver and there you should find plunger / switch with plastic pin, which can pop out.
    The plunger / switch base can break a `leg`which stops door from opening smoothly, which in turn can stop door opening completly or if it does open, the glove box door will `drop` without a light and no dampening.
    Cheers Anth
    part available as glove box plunger and switch - I think for around £15 ?!
    Last edited by anthonyj; 16-10-2007 at 11:01 PM. Reason: forgot to mention part and price
  6. Re: Glove box??
    Mar 2007
    Lancashire
    Quote Originally Posted by anthonyj View Post
    Cheers Anth
    Unbelievale, this must be another gremlin on the A4 Thanks for that info Anthony, I was about to start with taking the glove box apart, good to know that it's accessable from that panel. Makes sense what you say. I'll have to hope nothing has broken and I can simply fix.
    I'll let you know Mellie what the outcome is.
  7. Re: Glove box??
    Aug 2007
    Norwich
    Thanks. Not back home till wk end so couldn't do much anyway. Sounds pretty easy though.
  8. Re: Glove box??
    Aug 2007
    Norwich
    I managed to get home early and have a look at the glove box. Sure enough it had done exactly as anth said. Rather than buy a new one i just fed a plastic tyrap though tightened it up and cut off the excess. Stops the broken arm on the damper splaying open and letting the door just drop.
  9. Re: Glove box??
    Aug 2007
    Norwich
    I managed to get home early and have a look at the glove box. Sure enough it had done exactly as anth said. Rather than buy a new plunger / switch base i just fed a plastic tyrap though tightened it up and cut off the excess. Stops the broken arm on the damper splaying open and letting the door just drop.
  10. Re: Glove box??
    Aug 2007
    Norwich
    god knows what happened with two replies appearing.
  1. Glove Box Removal B6
    By Davidj241 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-06-2007, 12:54 AM
  2. glove compartment.
    By jamsb in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-06-2007, 11:38 AM
  3. Ticking glove box!!
    By Jum1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-05-2007, 09:09 AM
  4. Glove-Box
    By Pimped-Passat in forum Passat - Archive Topics
    Last Post: 29-03-2007, 11:38 PM
  5. Mk 4 Golf Glove Box Lid
    By hat 004 in forum New Member Introductions
    Last Post: 23-09-2006, 12:06 PM
