Thread: Data SIM & Bluetooth issue
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
  1. Data SIM & Bluetooth issue
    Dec 2015
    London
    13 Post(s)
    hi all,
    My A7 disconnects the phone on bluetooth when a data SIM is inserted into the MMI. As i learnt here earlier this was a bug in the earlier versions of the MMI (i have HN+_EU_AU_P0160), which should get resolved with an MMI software upgrade.
    Car is with the dealer right now for some bits and reported my symptoms and have suggested perhaps an MMI upgrade as a solution.
    Can i confirm that this is in fact an issue that should go away with an MMI upgrade, as am unsure if the dealer is aware of the symptom or the fix.
    tried to explain on the phone, have now written down as below to explain:
    1. Symptom: Whilst phone is connected on blue-tooth if i insert a data sim the phone on blue-tooth gets disconnected (alternatively if the data sim is already inserted the car will not connect a phone on blue-tooth). i have tried this with multiple phones as well, all of which connect on blue-tooth without any issue only if there's no data card.
    2. why i say this cannot be 'as designed':
    phone capability is unusable when a data sim is inserted, as the address-book is on the phone (not on the data sim).
    When the car initially pairs with a phone it does load up the address-book from the phone to the car, but when the car disconnects the phone on blue-tooth when a data sim is inserted the car no longer shows that address-book. So the phone-book becomes inaccessible.
    Have also advised them that i found the remedy via an AUDI forum
    cheers
    j
  2. Re: Data SIM & Bluetooth issue
    May 2013
    Wisbech
    8 Post(s)
    Yes issue will go away after update, just ask dealer to do update
  3. Re: Data SIM & Bluetooth issue
    Dec 2015
    London
    13 Post(s)
    phew
  4. Re: Data SIM & Bluetooth issue
    Feb 2013
    Gloucester
    57 Post(s)
    Yeah as above it should disappear after the update. If not there maybe an update that specifically sorts that issue but think it was part of the MMI software upgrade.
  5. Re: Data SIM & Bluetooth issue
    Jan 2016
    Essex
    Hi all, new around here
    Picked up my 2011 A7 the other week and have the same problem. Had a few emails with my local dealer (not where I bought the car) and they want to run diagnostics and charge for updates I think, I can't get a straight answer out of them at the moment. Is this something usually paid for? This is my first Audi so not dealt with the dealers before.
    Also, I notice I can do the update myself. Is this recommended or something to avoid?
  6. Re: Data SIM & Bluetooth issue
    May 2013
    Wisbech
    8 Post(s)
    Of course you will have to pay for update.
    Also you can do it yourself but the risk is high and small mistake, will kill your MMI.
  7. Re: Data SIM & Bluetooth issue
    Jan 2016
    Essex
    So I should pay for something that is effectively broken? It's crazy that you can't use a phone and internal SIM at the same time.
    I don't mind a small fee but they're quoting me £60 for diagnostics and then no mention of cost for the actual update.
    I'm currently choosing which of my local dealers to deal with so hoping one will be a little more friendly but I'm not holding my breath.
  8. Re: Data SIM & Bluetooth issue
    May 2013
    Wisbech
    8 Post(s)
    To be honest, before you bought your car, you could research for faults or issues on forum like this. Then ask dealer who was selling to you to do update of software and map in price of car otherwise you will not buy. Small blackmail but it works all the time. If you buy AUDI you have to be prepared for cost of servicing and diagnostics.
    £60 is normal working hour at AUDI dealer so not bad.
  9. Re: Data SIM & Bluetooth issue
    Jan 2016
    Essex
    It's a fair point and something I'll bear in mind in future. It's just that it's such a basic thing I guess I'd be expecting it to work. I'm all for paying for things, I just want a straight answer that they don't seem to be able to give me. Is it going to cost me £60 or £200? I've told them the issue and how to fix it, they just need to do it. I've done half the job for them
  10. Re: Data SIM & Bluetooth issue
    May 2013
    Wisbech
    8 Post(s)
    Just ask them to do software update for MMI and nothing else - no diagnostics , you are the client and you are demanding this to be done in car. Update takes around 40 minutes up to 1 hour. It depends from which version you are updating
  1. Bluetooth Phone and Dashboard Data SIM Card
    By Westyfield2 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 16-03-2016, 12:06 AM
  2. Question 4g data sim tarrifs
    By davetez in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 22-08-2015, 05:39 PM
  3. Bluetooth & SIM Card and great service.
    By SG77 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-06-2015, 06:30 PM
  4. Replies: 0
    Last Post: 21-05-2014, 12:46 AM
  5. Replies: 1
    Last Post: 09-05-2013, 06:34 PM
