Thread: locations of mirror fold module & power tailgate module ?
Results 1 to 9 of 9
  1. locations of mirror fold module & power tailgate module ?
    Dec 2015
    Southend, UK
    Does anyone happen to know where the control modules for the folding mirrors and the power tailgate are located on a C6 pre facelift Avant ?
    From the first week I bought this A6 I decided the two most important enhancements would be to make the mirrors fold on locking the car and to be able to close the tailgate from inside the car or at least from the key fob.
    Needing the ignition on to fold the mirrors in is frankly a bit dangerous as it means losing sight of traffic when opening the door to get out onto a busy road. What were they thinking ?
    Power tailgate opening quickly loses its appeal when passengers open the tailgate to get their clobber then cant work out what to do so the driver has to get out, walk round and press the close button on the back edge of the tailgate.
    ive not been able to find any VCDS tweaks which will achieve this on the pre facelift C6 (unless someone can tell me differently ?) so have decided to make physical wiring changes instead.
    Please can someone point me in the right direction of the location of these modules, I can then try to identify the pin outs and work out how to go about these mods.
    It really cant be that difficult. For instance both the button on the tailgate lip and the external tailgate button are able to close as well as open. Wring the button on the drivers door to work in the same way would seem easy enough- once located.
  2. Re: locations of mirror fold module & power tailgate module ?
    Jan 2011
    Stafford, UK
    I would think that the tailgate is wired that way for safety (to stop the driver from closing it on to someone loading/unloading).
    The folding mirrors operating when doors are locked has been discussed many times, without much success.
    I think that someone with an A3 has done it but can't find it.
    If you manage it, please let us know how you did it.
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  3. Re: locations of mirror fold module & power tailgate module ?
    May 2014
    Darlington
    78 Post(s)
    Modules that control the mirrors are in the driver & passenger doors. The central convenience module that control the tailgate is in the boot on the right hand side next to the fuses.
    2 0 0
  4. Re: locations of mirror fold module & power tailgate module ?
    Dec 2015
    Southend, UK
    Is there no centralised module for the mirror folding ?
  5. Re: locations of mirror fold module & power tailgate module ?
    Jul 2013
    76 Post(s)
    all that you need to do is plug the power fold mirror into the door module and change the coding to powerfold.
    Dan
    2009/2010 2.0 TDIe SE
  6. Re: locations of mirror fold module & power tailgate module ?
    May 2014
    Darlington
    78 Post(s)
    No there are 2 modules, one in either door.
    Some of the modules are not compatible with the power folding mirrors, the physical pins are not no the module too plug into. You may be able to code them with that option but they won't work.
  7. Re: locations of mirror fold module & power tailgate module ?
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    Quote Originally Posted by dan2485 View Post
    Sounds like he has power fold already but wants them to close on locking, not via the switch inside.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  8. Re: locations of mirror fold module & power tailgate module ?
    Dec 2015
    Southend, UK
    As far as i know the mirrors would have been plugged into the modules in the factory. What im trying to do here is make the mirrors fold when i want them to (on lock) rather than having to muck about with the control when the ignition is on which is frankly a bit pointless. Im looking for a wiring diagram for the modules so I can work out how to trigger them in a different way.
  9. Re: locations of mirror fold module & power tailgate module ?
    46 Post(s)
    A standard the car doesn't support it with factory software.
    NHN completed it on an A3 8P and so did some others, might be worth a google.
  1. Power fold wing mirror retrofit help
    By hsmithboy30 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-09-2014, 09:22 PM
  2. ABS Module: electrically connecting another module while not installed in the car?
    By dansansome in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-01-2014, 04:17 PM
  3. Replies: 5
    Last Post: 15-10-2012, 10:20 PM
  4. Comfort Module Coding Help Needed + Folding Mirror help
    By craig2210 in forum VCDS - Help Requests
    Last Post: 25-11-2009, 11:23 AM
  5. anyone used the one-touch module from cabrio-module.de on their A4 Cab?
    Last Post: 01-04-2008, 11:49 AM
