Thread: Audi A6 2.0 tdi rattle from engine
Results 11 to 20 of 27
  1. Re: Audi A6 2.0 tdi rattle from engine
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    Sounds almost like the pulley but in sure they will have checked that, strange.
  2. Re: Audi A6 2.0 tdi rattle from engine
    Mar 2016
    chicago US
    I have an 2004 s4 with a rattle problem ones warm..
    I found a video with exactly same noise,does anybody knows what it is?
    Pls let me know!
    start.MOV - YouTube
    Sent from my SM-G928T using Tapatalk
  3. Re: Audi A6 2.0 tdi rattle from engine
    May 2016
    yorkshire
    have you manage to get away with rattling in yours a6 ultra ?
  4. Re: Audi A6 2.0 tdi rattle from engine
    Jun 2008
    I get a very small rattle, like two small metal plates clapping against each other rapidly (sorry that's the best I can explain) I will upload a video later. It's coming from the driver side, and more profound towards the front driver side wheel. This is regardless of cold starts/days. Even after driving 25 miles and being idle it's still there. When I'm driving and it's in gear, it disappears. However, when it biting point and reversing up a slight incline you can hear it then as well. It can be intermittent, each time I've been into Audi (twice) it doesn't do it! So annoying. Anyone have any ideas?
    Audi A6 C7 2.0 TDI Ultra (Reg Sep 2015)
    MMI Navigation Full 4G Touch
    Parking System plus with automatic boot release
    Full Matrix LED Headlights with headlight washers
    Heated Windscreen washers
  5. Re: Audi A6 2.0 tdi rattle from engine
    Mar 2014
    Milford, Donegal, Ireland
    My very fresh A6 Ultra with now nearly 5K kmtrs on the clock also makes an additional noise on cold idle coming from the front of the engine, drivers side. It's like a hollow popping noise but it does go one the engine is warmed up. A mate of mine also on here has the same with his 2015 A6 Ultra. I'm just going to wait till the first service and leave them the car in the evening so they can start it from cold and check for themselves. The rattle from the rear is now fixed after they dropped the tamk and fixed in place whatever was loose.
    2017 A6 Avant Quattro SE Business 190 Ultra DSG 2017 Black, factory privacy glass, reversing camera, lighting package.
  6. Re: Audi A6 2.0 tdi rattle from engine
    Dec 2016
    Ireland
    Haven't had this problem on my A6 C7, but had it on a Ford Focus before, it was the heat shielding around the exhaust hitting off the exhaust. The heat shielding is very thin metal, pushed it back from exhaust by hand and problem solved.
  7. Re: Audi A6 2.0 tdi rattle from engine
    #17
    Mar 2014
    Happened to be out for a run with my local garage man yesterday and after we returned I started up the care for him to hear the noise I previously reported. He was very surprised at how noticeable it was and he agreed that it definitely should not be there. He contacted the Audi dealership this morning and they are to get back to him. It looks like a 2 hour trip to drop the car in for an inspection. I've taken a short video which I'm uploading so they can investigate that as well. I'll share the link on here once it's up.
    https://youtu.be/slfHUPHTcm4
  8. Re: Audi A6 2.0 tdi rattle from engine
    #18
    Mar 2014
    Ashford
    9 Post(s)
    My MY17 with only 4000 miles on the clock makes exactly this noise when it's cold too. I've got it booked in at the dealer for 2 weeks time but I'd love to know what diagnosis you get when yours goes in.
  9. Re: Audi A6 2.0 tdi rattle from engine
    #19
    Mar 2014
    Mine was collected today, hopefully will know more later this week...
  10. Re: Audi A6 2.0 tdi rattle from engine
    #20
    Mar 2014
    Just received a phone call from the workshop manager at the Audi Dealership. There is a notification (TPI he called it) with sound example on the Audi Technical Support for Dealers website which states that this sound is coming from the rotor in the vacuum pump which goes away when the coolant reaches roughly 60 degrees Celsius. Another way of 'killing the noise' after start up is to pump the brake pedal several times. Audi specifically mentions to not replace any components as it would have no effect. So basically they are saying it's a design related noise that is supposed to be there and is perfectly normal, nothing to worry about.
  1. A4 2.0 TDI - Engine Rattle on Start up
    By Mikehamilton in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-06-2014, 11:18 AM
  2. 2.5 TDI slight engine rattle 1600-1800 rpms
    By noetus in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-07-2013, 04:28 PM
  3. 2.0 TDI BLB engine rattle
    By P CRR in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-04-2013, 02:50 PM
  4. Audi 2004 S4 engine rattle from cold start up
    By peaty in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-03-2011, 08:42 AM
  5. A3 TDI (just had belts changed) but now a top engine rattle
    By sillydior in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 05-03-2010, 12:56 AM
