Thread: 1995 audi 80 cabriolet A.B.S. problem
Results 1 to 10 of 12
  1. 1995 audi 80 cabriolet A.B.S. problem
    Jan 2016
    edingale tamworth
    hi, my wifes 1995 audi 80 2.6 cabriolet has got a problem with the ABS system, the warning light on the dash is flashing and it feels like the ABS is on all the time. there is the correct level pentosin and the right level brake fluid. I have checked fuse 31 and this to is ok. i have started to check the speed sensors on each wheel i have unplugged the front sensors and checked with a multi metre and they are fine. i can not check the rear sensors because i can not find where the sensors plug in , i have removed the rear seat but still cant see where the connector plugs are for the sensors, can anybody tell me where they are or have a picture of the location. also if the sensors turn out to be ok what you advise i check next. thanks in advance.
  2. Re: 1995 audi 80 cabriolet A.B.S. problem
    134 Post(s)
    2009 Post(s)
    Turn the ignition on and watch the light, it will pulse in groups of four such as 4 4 4 4, which means no codes and then pause. There may be more than one code so watch carefully, note the codes and tell us.
  3. Re: 1995 audi 80 cabriolet A.B.S. problem
    Jan 2016
    edingale tamworth
    thanks for the reply, just to clarify that im counting the flashes of the light that looks like this (!). dont suppose you know where the connector plugs are for the rear abs sensors?
  4. Re: 1995 audi 80 cabriolet A.B.S. problem
    134 Post(s)
    2009 Post(s)
    Yes, the ABS warning light will flash with just the ignition on (engine not running) and it flashes in groups of four so for example, 4 then 4 then 4 then 4 is 4444 which means no codes. Worry about the codes first.
  5. Re: 1995 audi 80 cabriolet A.B.S. problem
    Jan 2016
    edingale tamworth
    the light that looks like this (!) is just flashing continuosly not in groups of four just keeps flashing away, i will sort this out myself in a methodical manner. if anyone does know the location of the rear abs sensor connectors please feel free to comment.
  6. Re: 1995 audi 80 cabriolet A.B.S. problem
    Dec 2007
    8 Post(s)
    The best methodical approach is what is being suggested by the best.
    The multimetre approach may tell if the sensor is reading within its limits. but it wont tell if it is not located properly etc.imo only
    Did you remove the sensors from the hubs or just the connectors.
  7. Re: 1995 audi 80 cabriolet A.B.S. problem
    Jan 2016
    edingale tamworth
    ok, i know about the abs sensors having to be the correct distance from the ring, on my year car there is a collet that makes setting them fool proof and i have new ones to install. just to clarify its the brake warning light that is flashing . i simply want to know the whereabouts of the abs sensor connectors on the back of the car.
  8. Re: 1995 audi 80 cabriolet A.B.S. problem
    Pembrokeshire
    22 Post(s)
    under the back seat.
  9. Re: 1995 audi 80 cabriolet A.B.S. problem
    Jan 2016
    edingale tamworth
    thank you, i have the rear seat removed could you tell me where abouts, are they similar connectors to the front sensors ?
  10. Re: 1995 audi 80 cabriolet A.B.S. problem
    Pembrokeshire
    22 Post(s)
    at either side you should see some wires that disappear downwards through the chassis, then come out underneath near the front of the rear axle. they should just be black plugs with 2 wires.
  1. audi cabriolet 1995 elec window problem
    By sonny in forum 80 - 90
    Last Post: 30-07-2010, 04:05 PM
  2. fan problem audi a6 1995
    By lionheart150 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 10-05-2010, 04:22 PM
  3. Audi A4 1995/6 key problem
    By Karx in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-04-2008, 07:08 AM
  4. Audi Cabriolet 1995 2.0e
    By andyc1978 in forum 80 - 90
    Last Post: 16-04-2008, 01:11 PM
  5. Replies: 1
    Last Post: 19-07-2007, 12:53 AM
