Thread: Flooded! AIRBAG warning light, Flooded interior, multiple warning lights AND Tiptronic safe mode
Results 1 to 10 of 11
  1. Flooded! AIRBAG warning light, Flooded interior, multiple warning lights AND Tiptronic safe mode
    Jan 2008
    Had a few snags with my tiptronic 1.9 TDI 54 reg. Drivers side flooded causing numerous issues. Leak sorted, it was the drain under the battery tray blocked. Auto transmission failed to safe mode, i replaced the auto transmission control unit (under floor in front of drivers seat) and that sorted also. Only remaining snag is the airbag light is illuminated. This was ok too until the leak. Does anybody know if a leak on the drivers (R/H) side would cause the airbag light to remain on? The passenger side is bone dry. Any advice would be greatly appreciated. Thanks.
  2. Re: Flooded! AIRBAG warning light, Flooded interior, multiple warning lights AND Tiptronic safe mode
    Oct 2015
    GB
    Any fault codes??
    Sent from my SM-A300FU using Tapatalk
  3. Re: Flooded! AIRBAG warning light, Flooded interior, multiple warning lights AND Tiptronic safe mode
    Jan 2008
    No fault codes. Just airbag light.
  4. Re: Flooded! AIRBAG warning light, Flooded interior, multiple warning lights AND Tiptronic safe mode
    Oct 2015
    GB
    Take battery out of car for 10 mins to clear clear fault, if appears then something else is leaking.
    Are you using vagcom?
  5. Re: Flooded! AIRBAG warning light, Flooded interior, multiple warning lights AND Tiptronic safe mode
    Oct 2015
    GB
    Learkin
  6. Re: Flooded! AIRBAG warning light, Flooded interior, multiple warning lights AND Tiptronic safe mode
    Jan 2008
    Ok will have a go at the battery tomorrow. No more leaks as drivers side now dry. My mate used his vag com but there were no codes?
  7. Re: Flooded! AIRBAG warning light, Flooded interior, multiple warning lights AND Tiptronic safe mode
    Oct 2015
    GB
    Disconnect battery and remove from engine bay, then touch eningine neg and pos cables together, leave for 10 mins and reconnect bat.
  8. Re: Flooded! AIRBAG warning light, Flooded interior, multiple warning lights AND Tiptronic safe mode
    Jun 2007
    There are two drains bungs, one under the battery and one directly under the brake servo. Clean and flush out both. Unusual to flood the drivers side unless the water got in via the electronics module in the plenum chamber. Did you trace the leak. ?
    When you dried the carpets have you disturbed the wiring under the seat or did the airbag light come on when it flooded. Regards Peter
  9. Re: Flooded! AIRBAG warning light, Flooded interior, multiple warning lights AND Tiptronic safe mode
    Jan 2008
    Noticed more water pooling again this morning this time drivers side up against the inner wing where the bonnet release cable breaks through the bulkhead. There is also a large black box containing electrical things. Basically a load of debris was wedged under the electrical box preventing trapped water to drain down to under the battery drain bung. Water could have possibley drained in to the car as there are several grommets in that area. I will keep an eye on this area. I tried to find drain bung under brake servo but could'nt see it?
    On the airbag front i disconnected battery for 30 mins and reconnected- light still on. Did not fancy touching battery leads + & - together as suggested earlier (will this cause damage?). There is an airbag fault displayed on the dash lcd display when you look in the service bit by pressing the stalk.
    Thanks for replies so far!
  10. Re: Flooded! AIRBAG warning light, Flooded interior, multiple warning lights AND Tiptronic safe mode
    Oct 2015
    GB
    It's a vw trick, no power running through it because battery is out.
    Ok well it could be ur claster dash unit, sometimes it's a solder joint that needs redoing.
    Have u checked all wires under seats etc?
  1. Blocked drain holes on a6 c5 2.4 auto avant flooded interior
    By JAAUDIA6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-01-2016, 10:20 AM
  2. Replies: 4
    Last Post: 14-03-2015, 08:25 PM
  3. Airbag light but also all other warning lights
    By colhot in forum Golf MK5 - 2004 - 2009
    Last Post: 01-04-2013, 06:56 PM
  4. ABS Warning light and no interior lights.
    By rallyfreaks in forum Golf MK4 - 1999 - 2004
    Last Post: 14-04-2011, 11:26 PM
  5. multiple warning lights - non starter
    By budgie-mog in forum Polo - Derby - Lupo - Fox
    Last Post: 06-06-2010, 04:41 PM
