Thread: Thermostat
Results 1 to 10 of 15
  1. Thermostat
    Sep 2015
    Forres, Scotland
    23 Post(s)
    Hi everyone! Somebody know where is thermostat in my car?
  2. Re: Thermostat
    Sep 2014
    Gjovik, Norway, Norway
    Quote Originally Posted by Sambor11 View Post
    Engine type?
  3. Re: Thermostat
    Sep 2015
    Forres, Scotland
    23 Post(s)
    I do apologise! Audi A6 C6 2.0 TDI 170bhp, march 2011 engine CAHA
  4. Re: Thermostat
    Jan 2011
    Stafford, UK
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
    2 1 0
  5. Re: Thermostat
    131 Post(s)
    1979 Post(s)
    I don't think it will make your heater work better.
  6. Re: Thermostat
    Sep 2015
    Forres, Scotland
    23 Post(s)
    I asked for it because yesterday driving 15 miles usually temperature reach 90 but it was just 80 and when parked on idle when down to 75,but heater I set on 20.5! I know! Little warn inside
    I thought that something happened with thermostat.Today I set heater on 18 and was all the time 90. Is yhe way it should be?
  7. Re: Thermostat
    Mar 2009
    Montenegro
    13 Post(s)
    Please note that there is one more thermostat, I have similar problem with my 2.0 TDIe 100kw. I have ordered this small one to see if it will help. I will let you know.
    Part number is 1K0 121 113 A, this is small thermostat which is on return hose from EGR cooler to 4/2 way valve with main thermostat and going directly to engine.
    I have notice that when engine does not have any load coolant temp is going down.
    We will see as soon as I remove this small thermostat is it good or not.
    I have found plenty BMW with this problem on site.
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  8. Re: Thermostat
    Jan 2011
    Stafford, UK
    Your heater is like another rad. if you are taking heat out of it your engine temp will go down.
    The engine doesn't make the heat on idle that it makes when driving, + it was cold yesterday.
  9. Re: Thermostat
    Mar 2009
    Montenegro
    13 Post(s)
    Maybe is not the problem, maybe it is like that during colder weather (as many forum members suggested). I have notice that as soon as ambient temperature is around 10 deg C or above, everything is ok and coolant temperature is steady on 90. Only that I am new to the car and my previous A4 did not have such behavior.
    Anyhow, I have ordered this small (EGR) thermostat.
    I will let you know what happen as soon as I replace it.
    Novak
  10. Re: Thermostat
    Sep 2015
    Forres, Scotland
    23 Post(s)
    Quote Originally Posted by royclark View Post
    It was cold yesterday.
  1. Question Thermostat
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-10-2013, 12:53 PM
  2. Please Help Another Thermostat ?
    By Dazzler01 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-03-2012, 03:02 PM
  3. Question thermostat
    By barrymorri in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-02-2012, 09:19 PM
  4. Please Help t5 thermostat
    By cashman in forum The Commercial Range
    Last Post: 08-03-2010, 08:03 PM
  5. Thermostat
    By animal in forum Polo - Derby - Lupo - Fox
    Last Post: 08-01-2010, 02:04 PM
