Thread: Missing 401 sender earth
Results 1 to 10 of 11
  1. Missing 401 sender earth
    Jan 2016
    Peterborough
    Hello, I'd really appreciate a bit of help as I'm struggling, I have a Audi S3 8P, after 4 years of trouble free driving my instrument cluster died, +12V was present on all pins that it should be, I checked the continuity of ground cables and found earth point 401 was open circuit, the only problem is I can't locate earth point 401 on the car. on the Audi current flow diagram it calls it "sender earth" and it says it's part of the "interior wiring harness"!
    Anybody know where this is exactly?
    This particular earth point is for the brake fluid level sensor, also fuel gauge, coolant level sensor, washer fluid level & the ambient temp sensor as well as the instrument cluster
    Note: I've rigged up a temporary earth cable directly into the cluster so this now powers up but all the above sensors are still dead
    Thanks in advance
    Cheers Paul
  2. Re: Missing 401 sender earth
    Dec 2007
    8 Post(s)
    Don,t know but a starting point may be door pillars area,possibly front n/s
    May be a large ground at pillar that connects to a bunch of lighter grounds in the loom.
    Hope you already found whats missing
  3. Re: Missing 401 sender earth
    Jan 2016
    Peterborough
    Hello mate, thanks for helping, I've had the trim off the door pillars near & offside, there were 4 X earth points, all were clean and metered out perfectly :-/. I think I've checked all the earth points shown in the wiring diagram but still car is faulty
  4. Re: Missing 401 sender earth
    Dec 2007
    8 Post(s)
    My thoughts were, that where the main ground from the pillar joins the small cluster in the loom,it may be losing contact somehow.
    I have seen some of these connections within the loom and and they would appear to be just wound together with a plastic cap for insulation (probably small exaggeration but).
    Maybe a good wiggle on parts of the loom while someone else looks for movement in the cluster instruments may just show a problem,or confine it to a smaller area.
    There are earth points under the battery tray, and I have seen reference to another in scuttle area,(Or next to cts in engine bay) (maybe another on steering column)
    Hopefully someone who has more experience with same will come along soon.
  5. Re: Missing 401 sender earth
    Jan 2011
    East Kent
    Maybe forum member NHN could help.
    Previous: 2005 A3 1.9tdi SE
    2009 Audi A3 2.0tdi 138bhp SE
  6. Re: Missing 401 sender earth
    Jan 2016
    Peterborough
    I hope so mate, it's really doing my head in.
    Ref Michael I think I know the type off connections you refer too, I've seen one behind the dashboard, it looked fine but I can check it with a meter.
  7. Re: Missing 401 sender earth
    Jan 2011
    East Kent
    He is most active on the Audi sport forum but you can send him a pm.
  8. Re: Missing 401 sender earth
    Dec 2007
    8 Post(s)
    Hello again PMartin,
    An old post indicates an earth point in the engine bay,close to the c.t.s.(with photo) ,and this can cause the instrument cluster to go dead if in poor condition.
    It would be worth checking out,although my A3 does not have this connection. Maybe yours will have it.
  9. Re: Missing 401 sender earth
    Jan 2016
    Peterborough
    Ok, What do you mean by cts?
  10. Re: Missing 401 sender earth
    Jan 2016
    Peterborough
    Sorry I guess coolant temperature sensor?!
  1. Missing Label File - 059-907-401-ASB.LBL
    By digger42 in forum VCDS - General Questions
    Last Post: 10-05-2014, 07:20 PM
  2. Question Is the water temp sender the same as the fan temp sender?
    By 1969ghia in forum Touran - Sharan - Caravelle
    Last Post: 01-06-2010, 06:42 PM
  3. Please Help Where to earth my sub to?!
    By VictoryWorks in forum Golf MK4 - 1999 - 2004
    Last Post: 15-11-2008, 07:45 PM
  4. Possible Earth
    By Peanut in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-12-2007, 12:32 PM
  5. MS Visual Earth
    By Baron_Samedi in forum Home Tech Shed
    Last Post: 09-11-2007, 02:36 PM
