Thread: Need Help Deciding on Best Course of Action - DPF/Sensor
Results 1 to 9 of 9
  1. Need Help Deciding on Best Course of Action - DPF/Sensor
    Feb 2015
    Hello
    Wife's A4 B8 2.0TDI is crying (again). Engine management lamp has flashed up a couple of days ago with
    5162 - Diesel Particle Filter; Differential Pressure Sensor (
    P245300 [101] - Implausible Signal
    5188 - Diesel Particle Filter
    P246300 [175] - Excessive Soot Accumulation
    I cleared the fault on VCDS, monitored the pressure sensor and soot loading and took the car for a good run on the motorway. Soot loading was around 10-20mg, engine management lamp stayed off.
    I have come home from work this evening to be informed that the light is on again and the "coil" light is also flashing. Message on dash gives a warning about DPF and to consult manual.
    I have just done a fault code scan again this evening the results of which are below.
    I really don't want to have to spend a fortune on a new DPF nor waste cash on professional DPF cleaning if it is not going to help. From the little on have done on the web to research this problem it looks like there is a chance it is just a pressure sensor that is at fault. Soot loading is now 35-45mg......is this too high to force a regen?
    Any help appreciated (this evening) as we need to use the car Thursday and Friday. I suspect it has kicked into limp mode now too.
    PHP Code:
    Chassis Type8K (8T0)
    VIN:   Mileage:166420km-103408miles
    01
    -Engine -- StatusMalfunction 0010
    03
    -ABS Brakes -- StatusOK 0000
    04
    -Steering Angle -- StatusOK 0000
    05
    -Acc/Start Auth. -- StatusOK 0000
    08
    -Auto HVAC -- StatusOK 0000
    09
    -CentElect. -- StatusOK 0000
    15
    -Airbags -- StatusOK 0000
    16
    -Steering wheel -- StatusOK 0000
    17
    -Instruments -- StatusOK 0000
    19
    -CAN Gateway -- StatusMalfunction 0010
    42
    -Door ElectDriver -- StatusOK 0000
    46
    -Central Conv. -- StatusMalfunction 0010
    47
    -Sound System -- StatusOK 0000
    52
    -Door ElectPass. -- StatusMalfunction 0010
    53
    -Parking Brake -- StatusOK 0000
    55
    -Headlight Range -- StatusOK 0000
    56
    -Radio -- StatusOK 0000
    62
    -DoorRear Left -- StatusOK 0000
    69
    -Trailer -- StatusOK 0000
    72
    -DoorRear Right -- StatusOK 0000
    77
    -Telephone -- StatusOK 0000
    Address 01Engine(J623-CAGA)       Labels03L-906-022-CAG.clb
       Part No SW
    03L 906 022 JM   HW03L 906 022 B
       Component
    R4 2,0L EDC   H013173
       Revision
    11H01---
    Coding0104002C18072118
       Shop
    #: WSC 00460 210 56321
    ASAM DatasetEV_ECM20TDI03L906022JM A01005
       ROD
    EV_ECM20TDI03L906022B.rod
       VCID
    79FE6157F8A053F636-802C
    3 Faults Found
    5182 Particulate Trap Bank 1
              P200200
    [101] - Efficiency Below Threshold
              NotConfirmed
    Tested Since Memory Clear
                Freeze Frame
    Fault Status00000001
                       Fault Priority
    2
                       Fault Frequency
    1
                       Mileage
    166319 km
                       Date
    2016.01.18
                       Time
    18:03:08
    5188
              P246300
              MILON
    Confirmed Tested Since Memory Clear
                Freeze Frame
                       Fault Priority
    2
                       Fault Frequency
    7
                       Mileage
    166414 km
                       Date
    2016.01.20
                       Time
    13:52:13
    5162
    Diesel Particle FilterDifferential Pressure Sensor
              P245300
              NotConfirmed
                Freeze Frame
                       Fault Priority
    2
                       Fault Frequency
    1
                       Mileage
    166420 km
                       Date
    2016.01.20
                       Time
    14:00:49
    Readiness
    1 1 0 0 0
    Address 03ABS Brakes(J104)       Labels8K0-907-379-V1.clb
       Part No SW
    8K0 907 379 AA   HW8K0 907 379 AA
       Component
    ESP8 front    H040060
       Revision
    : --------   Serial number: --------------
    Coding168500
       Shop
    #: WSC 01130 210 66681
    VCID78F86453CBAA4AFE49-802C
    No fault code found
    Address 05Acc/Start Auth.(J393)       Labels8K0-907-064-05.clb
       Part No SW
    8K0 907 064 N    HW:8K0 907 064 N
       Component
    BCM21.1      H80 0143
       Revision
    00002001
       Coding
    031200
       Shop
    #: WSC 06335 000 00000
    VCID3B72BB5FBA1CA1E664-806E
       Subsystem 1
    Part No SW8T0 959 754D    HW8T0 959 754 D
       Component
    FBSAUDIB8 IDG  H37 0060
       Subsystem 2
    Part No SW8K0 905 852D    HW8K0 905 852 D
       Component
    ELVAUDIB8  H36 0041
    No fault code found
    Address 08Auto HVAC(J255)       LabelsRedir Fail!
    Part No SW8T2 820 043 S    HW:8T2 820 043 S
       Component
    KLIMA 3 ZONEN H06 0140
       Revision
    D0000000   Serial number0117.09.080029
       Coding
    34040000
       Shop
    VCID428CC6BBDDF6D02E27-8016
    No fault code found
    Address 09CentElect.(J519)       Labels8K0-907-063.clb
       Part No SW
    8K0 907 063 C    HW:8K0 907 063 C
       Component
    BCM11.0      H22 0253
       Revision
    04022001   Serial number00000000233799
       Coding
    :260050914034AF010001000000001D0D001D070800010141000000
       Shop
    VCID2F6A9F0F7E644D46D8-807A
       Subsystem 1
    Part No SW8K2 955 119A    HW8T2 955 119   Labels1KX-955-119.CLB
       Component
    WWS 190908  H05 0070
       Coding
    00FD11
       Subsystem 2
    Part No SW8K0 955559     HW8K0 955 559   Labels8K0-955-559.CLB
       Component
    RLS  H04 0003
       Coding
    025028
       Subsystem 3
    Part No SW8K0 941 531G    HW8K0 941 531 G
       Component
    E1 LDS  H07 0070
    No fault code found
    Address 15Airbags(J234)       Labels8K0-959-655.clb
       Part No SW
    8K0 959 655 B    HW:8K0 959 655 B
       Component
    AirbagVW-AU10 H27 0410
       Serial number
    0038JD1B8TRX
       Coding
    :30363435363030303030554A3052384B3053
       Shop
    ASAM DatasetEV_AirbaECUVWAUDI010 A02007
       ROD
    EV_AirbaECUVWAUDI010_AU48.rod
       VCID
    3C70B843B712A6DE6D-8068
       Crash sensor
    for side airbagdriver side
    Serial number6334MSME41742610+
    Crash sensor for side airbagfront passengerside
    Serial number6344MSME4163012F6
       Crash sensor
    for side airbagreardriverside
    Serial number6352QSME4C0700246
       Crash sensor
    for side airbagrearpassengerside
    Serial number6362QSME760A1E18P
       Crash sensor
    for front airbagdriver side
    Serial number63732SME0B0A572E5
       Crash sensor
    for front airbagfront passengerside
    Serial number63832SME0D0A003A-
    No fault code found.
    Address 16Steering wheel(J527)       Labels8K0-953-568.clb
       Part No SW
    8K0 953 568 G    HW:8K0 953 568 G
       Component
    Lenks.Modul   H160014
       Revision
    : --------   Serial number90319IDP0003N
       Coding
    000017
       Shop
    VCID3E74B24BA90EB4CE43-806A
       Component
    E221 MFL  H02 0003
    No fault code found
    Address 17Instruments(J285)       Labels8T0-920-xxx-17.clb
       Part No SW
    8K0 920 980 B    HW:8K0 920 980 B
       Component
    KOMBIINSTR.   H170224
       Revision
    00100000   Serial number9E356KX98
       Coding
    2F04100002002600010000
       Shop
    VCID316E997768505BB6CE-8064
    No fault code found
    Address 19CAN Gateway(J533)       Labels8T0-907-468.clb
       Part No SW
    8T0 907 468 H    HW:8T0 907 468 H
       Component
    GW-BEM 5CAN   H060094
       Revision
    4GB20042   Serial number4200G089018527
       Coding
    000303
       Shop
    VCID4684DAABF1DEEC0E0B-8012
       Subsystem 1
    Part No SW8K0 915 181B    HW8K0 915 181 B
       Component
    J367-BDM  H04 0150
    1 Fault Found
    03041 Energy Management Active
                000
    -  -  - Intermittent
                Freeze Frame
    Fault Status00100000
                       Fault Priority
    7
                       Fault Frequency
    3
                       Reset counter
    28
                       Mileage
    166394 km
                       Time Indication
    0
                       Date
    2016.01.19
                       Time
    17:40:00
    Address 42Door ElectDriver(J386)       Labels8K0-959-793.clb
       Part No SW
    8K0 959 793 C    HW:8K0 959 793 A
       Component
    TSGFA        H10 0170
       Revision
    :            Serial number0000007795281
       Coding
    011002204001410001
       Shop
    VCID4088CCB3D3FAC23E31-8014
    No fault code found
    Address 46Central Conv.(J393)       Labels8K0-907-064-46.clb
       Part No SW
       Component
    BCM21.1      H80 0143
       Revision
    00002001   Serial number0114948008
       Coding
    013B062220390440002002
       Shop
       Subsystem 1
    Part No8K0 951 177
       Component
    DWA-Sensor  H02 0040
    1 Fault Found
    01134 Alarm Horn (H12
    004No Signal/Communication
                Freeze Frame
    Fault Status01100100
                       Fault Priority
    2
                       Fault Frequency
    1
                       Reset counter
    235
                       Mileage
    166018 km
                       Time Indication
    0
                       Date
    2016.01.15
                       Time
    17:09:32
    Address 47Sound System(J525)       Labels8T0-035-223-ASC.clb
       Part No SW
    8T0 035 223 AB   HW8T0 035 223
       Component
    DSPSTD       H07 0220
       Revision
    S2100000
       Coding
    0203010102
       Shop
    VCID6ED4420BB9EE044E93-803A
    No fault code found
    Address 52Door ElectPass.(J387)       Labels8K0-959-792.clb
       Part No SW
    8K0 959 792 C    HW:8K0 959 792 A
       Component
    TSGBF        H10 0170
       Revision
    :            Serial number0000007793631
       Coding
    011002204001410001
       Shop
    VCID3F8ACF4FAE04BDC648-806A
    1 Fault Found
    02115 Locking Unit for Central Locking
                008
    Implausible Signal
                Freeze Frame
    FaultStatus01101000
                       Fault Priority
    3
                       Fault Frequency
                       Reset counter
    243
                       Mileage
    166018 km
                       Time Indication
    0
                       Date
    2016.01.15
                       Time
    17:25:39
    Address 53Parking Brake(J540)       Labels8K0-907-801-V1.clb
       Part No SW
    8K0 907 801 E    HW:8K0 907 801 E
       Component
    EPB Audi B8   H050060
       Revision
    00000003   Serial number10000000105494
       Shop
    #: WSC 00000 000 00000
    No fault code found
    Address 55HeadlightRange        Labels8K0-907-357.clb
       Part No
    8K0 907 357 B
       Component
    Dynamische LWR  H01 0030
       Revision
    00000001   Serialnumber:
    Coding0000004
       Shop
    #: WSC 06334 000 00000
    VCID3460906357426E9EA5-8060
    No fault code found
    Address 56Radio (J503)      Labels8Tx-035-1xx-56.clb
       Part No SW
    8T2 035 186 C    HW:8T2 035 186 C
       Component
    :Concert3      H02 0210
       Revision
    00000004   Serial numberAUZ5Z6H1127183
       Coding
    0502008201028D000359070000
       Shop
    VCID3878A4538B2A8AFE89-806C
       Subsystem 1
    Part No SW8T0 919 603A    HW8T0 919 603 A
       Component
    Display
    No fault code found
    Address 62DoorRear Left(J388)       Labels8K0-959-795.clb
       Part No SW
    8K0 959 795 A    HW:8K0 959 795 A
       Component
    TSGHL        H06 0170
       Revision
    :            Serial number0000007730385
       Coding
    010002204001210001
       Shop
    No fault code found
    Address 69Trailer(J345)       Labels8K0-907-383.clb
       Part No SW
    8K0 907 383 E    HW:8K0 907 383 E
       Component
    Anhaenger    H09 0100
       Revision
    1A001001   Serial number00000181006587
       Coding
    0100000000000000
       Shop
    VCID3664AA6B813E7C8E9B-8062
    No fault code found
    Address 72DoorRear Right(J389)       Labels8K0-959-794.clb
       Part No SW
    8K0 959 794 A    HW:8K0 959 795 A
       Component
    TSGHR        H06 0170
       Revision
    :            Serial number0000007798437
       Coding
    010002204001210001
       Shop
    No fault code found
    Address 77:Telephone        Labels8P0-862-335.lbl
       Part No SW
    8T0 862 335 C    HW:8T0 862 335 C
       Component
    FSE_256x BT    H33 0550
       Revision
    00000000   Serial number00000005034418
       Coding
    0010320
       Shop
    VCID3A7CBE5B752698EE7F-806E
    No fault code found
  2. Re: Need Help Deciding on Best Course of Action - DPF/Sensor
    Feb 2015
    Where is the differential pressure sensor located? Does it need to be recoded/adapted after installation or will it self learn?
  3. Re: Need Help Deciding on Best Course of Action - DPF/Sensor
    Feb 2015
    I am getting there slowly but would appreciate it if any one could reassure me of my assumptions and direction! I have now located the sensor in the engine bay and the part costs £40 from Europarts.
    I have also driven the car this morning. It started off in limp mode and then after 500m of driving back to "normal" performance. I drove the vehicle to my workplace which was a 70minute "spirited" drive and logged the DPF measurement blocks via VCDS. At the end of the drive all error lamps were off on the dash board but the CAN had logged single fault during the drive :
    P245300
    [101] -
    Implausible Signal
    I have attached a screenshot of the logging file charts. The things of note are:
    - Seems to be regenerating (on a passive basis)
    - Soot loading at 37g when it was in "limp" mode but subsided to about 5-10g after regeneration
    Q - how often should the DPF regenerate under normal conditions? Have I got an underlying problem here EG clogged injectors, burning oil (although the engine oil levels are remaining stable)
    Q - Particle Filter; difference pressure seems to remain quite stable - I would expect this to rise and fall as the soot load varies; indeed is this not how the ECU calculates the soot loading in the DPF!?? Also this parameter did not fluctuate much with engine revs.....is this normal??
    Assistance would really be appreciated.
  4. Re: Need Help Deciding on Best Course of Action - DPF/Sensor
    Sep 2013
    leatherhead, UK
    FWIW i had my DPF sensor swapped out 2 weeks ago after I had ecatly the same symptons tha you are experinceing. Yellow lights everywhere, glow plug DPF etc. EMS light stayed on and forced me to get it checked out by a good local indep that I have faith in. 30 minute swap out of DPF sensor fixed all problems and back to happy motoring again.
    If you can change it for £40 parts - go ahead. small cost and it's a bit of kit that has legacy issues anyway.
    Hope it helps.
    Audi A4 Avant B8 3.0TDI (240)
    Caterham 7 K series 1.8 150 ps
  5. Re: Need Help Deciding on Best Course of Action - DPF/Sensor
    134 Post(s)
    2016 Post(s)
    "swapped out" . Fit a new DPF pressure sensor, re-adapt it and see what happens, 90% of the time this works or you may have to "change out" the DPF
  6. Re: Need Help Deciding on Best Course of Action - DPF/Sensor
    Sep 2013
    leatherhead, UK
    OK so that is the more technically pure response. So let's do as the purist said - sawp it out for a new one.
  7. Re: Need Help Deciding on Best Course of Action - DPF/Sensor
    Feb 2015
    Looks like I am installing a new sensor Tomorrow then!! Any tips on the re-adapt process ahead of an evening of googling!!!??
  8. Re: Need Help Deciding on Best Course of Action - DPF/Sensor
    Feb 2015
    Fixed. DPF sensor changed. As soon as I carried out the adaption I could tell it was working as I was seeing sensible values via the graphing function on VCDS. Hope the is useful to someone else.
    1 1 0
  9. Re: Need Help Deciding on Best Course of Action - DPF/Sensor
    andyam Guest
    Quote Originally Posted by men8idw View Post
    Sorry to revive an old thread but what was he part number you used? 059906051c or 059906051A? audi quoted me £67 for the part but I've found Bosch ones for £30....
  1. DPF pressure sensor or just a blocked DPF
    By dan2485 in forum VCDS - General Questions
    Last Post: 30-04-2018, 09:24 AM
  2. DPF sensor reset
    By mhobson in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-06-2015, 02:44 PM
  3. Newbie needs help deciding
    By Ricardoo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-10-2012, 04:04 PM
  4. DPF Sensor
    By magt1000 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-08-2011, 04:26 PM
  5. Used Audi A3 - 1.6 or 1.9tdi - need help deciding
    By patomlin76 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-06-2010, 01:29 PM
