Thread: Stop/Start
  1. Stop/Start
    Great Dunmow (near Stansted Airport), Essex
    Just a quick one,
    On my Superb Greenline the stop/start function sometimes doesn't come into play, so when I apply the handbrake and select neutral the little stop/start symbol appears, but with a line through it. Why may this be? I understand it will be the case when the engine is cold, but after a good hour's trip it sometimes does it too.
    Sent from my HTC One_M8 using Tapatalk
    1990 Black MKII Golf 1.8 GL. Otherwise known as 'Gumpert' Rampant "Rabbit"
    2011 Rosso Brunello Skoda Superb Estate Elegance 1.6 CR Greenline. Otherwise known as 'Sue'
    1988 Tornado Red MKII Golf 1.8 16valve GTI. Otherwise known as 'Hollie' - Project
  2. Re: Stop/Start
    Feb 2004
    Yorkshire
    49 Post(s)
    Stop/Start is one of those things that seems to have a mind of its own... There are a lot of things that need to be just right before it will work.. Mine is a DSG so when I come to a halt it works just off the brake pedal pressure, hard press it activates, light press it keeps running..
    In the handbook it gives you a list, but suspect a few more things are taken into consideration Lol
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Ways to support the website
  3. Re: Stop/Start
    Yeah I think there are things to do with operating temperature, steering wheel position, DPF regeneration etc. Quite a complex set of checks it must complete before deciding it's ok to commence the stop/start function!
  4. Re: Stop/Start
    Feb 2004
    Yorkshire
    49 Post(s)
    In fact I have been out in mine today, did 12 miles and the stop/start did not work.. Lol
  5. Re: Stop/Start
    Managed to source this info:
    The stop / start system is quite a complicated process with a varying number of influences...
    Conditions for the automatic engine shut down (stop phase)
    ›*The gearshift lever is in Neutral.
    ›*The clutch pedal is not depressed.
    ›*The driver has fastened the seat belt.
    ›*The driver's door is closed.
    ›*The bonnet is closed.
    ›*The vehicle is at a standstill.
    ›*The engine is at operating temperature.
    ›*The charge state of the vehicle battery is sufficient.
    ›*The stationary vehicle is not on a steep slope or a steep downhill section.
    ›*The engine speed is less than 1200 1/min.
    ›*The temperature of the vehicle battery is not too low or too high.
    ›*There is sufficient pressure in the braking system.
    ›*The difference between the outdoor- and the set temperature in the interior is
    not too great.
    ›*The vehicle speed since the last time the engine was switched off was greater
    than 3 km/h.
    ›*The front wheels are not turned excessively (the steering angle is less than 3/4
    of a steering wheel revolution).
    Conditions for an automatic restart (start phase)
    ›*The clutch is depressed.
    ›*The max./min. temperature is set.
    ›*The Defrost function for the windshield is switched on.
    ›*A high blower stage has been selected.
    ›*The START STOP button is pressed.
    Conditions for an automatic restart without driver intervention
    ›*The vehicle moves at a speed of more than 3 km/h.
    too great.
    ›*The charge state of the vehicle battery is not sufficient.
    ›*There is insufficient pressure in the braking system.
  1. Stop start
    By MatC in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-06-2015, 11:33 PM
  2. How does Start/Stop interplay with Stop-Go on the ACC?
    By Timothy Nathan in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-02-2012, 11:40 AM
  3. start - stop (or rather not)
    By ti rich in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 01-02-2012, 10:28 PM
  4. Start Stop
    By Tony2 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-03-2010, 09:32 AM
  5. Stop/Start
    By Toltol in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-02-2010, 09:06 AM
