Thread: V6 tdi known engine problems
  1. V6 tdi known engine problems
    Aug 2007
    Asnières-sur-Blour, Vienne, France
    9 Post(s)
    I am interested to find known engine problems so I may be able to prevent issues. I have read about the oil pump issues with the 2.0 tdi and have a neighbour with a 2.0 tdi A4 cab with only about 80, 000 miles whose oil pump failed and the engine and turbo were wrecked. I have two late 2006 cars with 3.0 tdi engines, both have had the inlet manifolds changed and I know there are issues with the metal quality of the timing chain tensioner pulley, but so far no rear engine rattles on startup, but are there any other major issues I should look out for?
    Michael
  2. Re: V6 tdi known engine problems
    Sep 2015
    widnes uk
    I'm no expert but my experience of problems on the 3.0 a6 -
    Throttle body issues
    Egr valve
    Intake manifolds
    Swirl flaps
    A few threads on here which explain in more detail if you search
    Otherwise I find its a great all round car
  3. Re: V6 tdi known engine problems
    May 2014
    Darlington
    78 Post(s)
    Main issues are tensioners, injectors & inlet mainfolds. Also to look out for is the crank pulley.
  1. Please Help A6 2.5 TDI AKE engine problems
    By robotelu97 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-07-2015, 07:25 AM
  2. Audi A2 Tdi 54 plate engine problems
    By iworld in forum A2
    Last Post: 26-12-2011, 09:14 PM
  3. Problems with 1.9 TDI Engine - strange noises
    By DBSK in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-12-2009, 05:18 PM
  4. 130 TDI PD Engine Problems
    By alfa145 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-09-2008, 06:45 PM
  5. a4 tdi engine problems
    By shuggy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-12-2007, 10:57 AM
