Thread: Working temperature on 2.0 TDIe during winter time
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
  1. Re: Working temperature on 2.0 TDIe during winter time
    #21
    Mar 2009
    Montenegro
    13 Post(s)
    I suppose that gauge is OK as this happen only when heating is on, ambient temp is below 10 degrees C and engine does not have any load (going downhill). Heating in cabin is OK all the way (anyhow, car has auxiliary heating. So when there is no heating from engine it switch on this auxiliary heating).
    I will monitor it these days, but, I had A4 with 1.9 tdi PD, and gauge was steady on 90 all the time, can go down but only when outside is 15-20 below 0.
    I dont like if something is wrong to take it as it is. I am new to the car, this is may first winter with it, maybe is normal like that, but will see these days (will try to contact somebody who has same car and engine).
    I only regret that I did not change that thermostat when I was doing timing belt. Good or bad it does not mettar. But next time will be different. This should be considered as consumable part.
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  2. Re: Working temperature on 2.0 TDIe during winter time
    #22
    Jul 2015
    Staffs
    46 Post(s)
    I don't believe the thermostat should be considered a consumable part.
    5 years is nothing for a 'stat. I've driven 20+ year old cars on the original. I would say they outlast the coolant rad on most cars.
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: Working temperature on 2.0 TDIe during winter time
    #23
    Mar 2009
    Montenegro
    13 Post(s)
    On my previous A4, thermostat failed on 180000 km and 7 years old car. It failed on summer time and I got similar issue, going downhill on ambient temperature of 30 degrees the gauge falling down (with A/C on). So, I am now on same km but car has 5 years, the coolant and everything other were original until timing belt change and now I have new original coolant G13, new original pump and new original small thermostat. I am thinking to change as well new original thermostat.
  4. Re: Working temperature on 2.0 TDIe during winter time
    #24
    May 2007
    Novica - did you come to any conclusion on this?
  5. Re: Working temperature on 2.0 TDIe during winter time
    #25
    Mar 2009
    Montenegro
    13 Post(s)
    Quote Originally Posted by necstandards View Post
    Yes, the engine is working like this. Good friend of mine had A4 (B8) with same engine and less mileage, he changed thermostat (both) and same thing happens. I will change thermostat on next timing belt change. I noticed that if the car is driven on highway on low temperatures the engine is maintaining its working temperature, I suppose that engine will not even reach working temperature if something is wrong. These are high efficient engines.
    Sent from my LG-D802 using Tapatalk
  6. Re: Working temperature on 2.0 TDIe during winter time
    #26
    Jul 2015
    Staffs
    46 Post(s)
    Have you actually performed any live data on the coolant temp? I wouldn't trust a dashboard gauge.....usually they read 'low', 'normal' or 'head gasket has gone'.
    Ian
  7. Re: Working temperature on 2.0 TDIe during winter time
    #27
    Jul 2013
    76 Post(s)
    Have you had the system vacuum bled to rule trapped air?
    Dan
    2009/2010 2.0 TDIe SE
  8. Re: Working temperature on 2.0 TDIe during winter time
    #28
    Mar 2009
    Montenegro
    13 Post(s)
    @dan2485 I have not performed any vacuum bled. I suppose that if there were any air trapped will be untrapped after passed 32000km and 2 years. So far car is getting fast working temp, on highway is not losing temp at all, only happen when there is no load on engine and out temp is les then 10 deg C.
  9. Re: Working temperature on 2.0 TDIe during winter time
    #29
    Mar 2013
    Kaohsiung, Taiwan
    Hi, I know this is an old thread, but I am having the same problem with my A6 C7's CGLC engine. I recently changed the main thermostat but problem did not go away. Now I am thinking about changing the second thermostat (the one for EGR cooler), but before I do that I wonder if it's worth replacing the coolant temperature sender (G62).
    I logged temperatures of G62 and G83 using VCDS, temperatures for both sensors increased together. So I thought the main t-stat was stuck open causing cold coolant to go into the engine. Upon inspection of old t-stat, it did not look stuck open, and the replacement did not solve the problem. Meaning main t-stat probably wasn't the cause of problem. Could the second t-stat be stuck open causing cold fluid to go into the engine? What do you guys think? Has any one changed both t-stats and solved the problem?
    Thanks.
  10. Re: Working temperature on 2.0 TDIe during winter time
    #30
    Feb 2023
    Shrewsbury, UK
    Quote Originally Posted by dcheng View Post
    Thanks.
    I have same problem, I have replaced egr thermostat, main thermostat and non return valve, no difference so far.
    I don't think its normal, if coolant isn't up to temp the DPF won't regen.
  1. Winter's here - It's Webasto time
    By Rob69 in forum Touran - Sharan - Caravelle
    Last Post: 06-12-2014, 11:28 PM
  2. 3rd brake light not working , no revs , engine mangement on from time to time
    By icemano3 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-10-2013, 10:01 PM
  3. A4 TDIe Engine Warmup time?
    By tourer2 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-06-2012, 07:58 PM
  4. Need ideas for the winter time project!
    By Aug in forum Golf MK3 - 1993 - 1999
    Last Post: 15-08-2008, 02:07 AM
