Thread: Drivers door locked
Results 1 to 10 of 16
  1. Drivers door locked
    May 2012
    essex
    Not got a chance at moment due to injured wrists but the drivers door won't open from the outside when unlocked. Only way of opening Is via the inside handle, sounds like locks operates ok just when you pull handle nothing.
    Still no vcds here, just wondered if it common issue
    2007 3.0tdi asb le mans
    hybrid turbo, decat,miltek, 20's etc
    330-350 bhp
    450-500lbst
    2007 3.0 tdi le mans : Hybrid turbo decat : miltek etc : 330-350 bhp : 450-500lbsft
    Visibility pack. Adaptive xenon, Privacy glass. Bose surround. Dvd nav. Comms pack, led plate lights.
    Miltek, custom map,hybrid turbo, decat improved airflow to intercoolers.
  2. Re: Drivers door locked
    May 2014
    Darlington
    78 Post(s)
    Very common, there are a good few threads about it. Needs a new / replacement locking mechanism.
  3. Re: Drivers door locked
    May 2012
    essex
    With my present condition of 2 knackered wrists a job for my local indie looking at your write up.
    Locks about 150 new? Plus hour labour?
    330-350 bhp
    450-500lbst
  4. Re: Drivers door locked
    May 2014
    Darlington
    78 Post(s)
    Yep around that on cost, and around an hour to do.
  5. Re: Drivers door locked
    May 2012
    essex
    Tar. I'll call my indie tomorrow to book it in. I can't drive at present and my wife's pregnant so she struggling to reach across to use inside handle. Needs fixing asap
    330-350 bhp
    450-500lbst
  6. Re: Drivers door locked
    May 2014
    Darlington
    78 Post(s)
    Yes it's a pain, at some point it may start working again then fail again!, it's bad micro switches inside the lock. I've had to replace driver & passenger sides.
  7. Re: Drivers door locked
    May 2012
    essex
    Is the lock main dealer only or any decent patent. If a common issue don't see the point in secondhand.
    330-350 bhp
    450-500lbst
  8. Re: Drivers door locked
    46 Post(s)
    genuine all the way, inferior parts are crap and won't last.
  9. Re: Drivers door locked
    May 2012
    essex
    It would seem the genuine aren't exactly fail safe seeing how common it is.
    330-350 bhp
    450-500lbst
    1 1 0
  10. Re: Drivers door locked
    46 Post(s)
    baring in mind yours has probably been in there since new, 9 years ago. a copy one wouldn't last 9 months.
  1. Replies: 8
    Last Post: 19-08-2009, 09:23 PM
  2. Rear drivers door locked shut.
    By gbdxo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-02-2009, 03:44 PM
  3. locked door
    By fgarau in forum Bora - 1998 - 2005
    Last Post: 24-07-2008, 04:02 PM
  4. Drivers side rear door locked
    By Fettler in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 12-04-2008, 10:33 AM
  5. locked rear drivers side passenger door
    By marcj in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-05-2007, 07:51 PM
