Thread: A3 Start Judder
Results 1 to 8 of 8
Hybrid View
  1. A3 Start Judder
    Dec 2015
    yorkshire
    recently purchased a audi a3 1.9tdi E special edition its been spot on all but the past few days.
    When I twist the key to start the car there is a shudder from the engine then it dies.
    if i twist the key again it usually starts or it will take another go.
    Its recently had a brand new flywheel and clutch fitted and has been serviced well.
    The car drives perfectly fine
    any help would be appreciated
    gav.
  2. Re: A3 Start Judder
    Jul 2015
    Staffs
    46 Post(s)
    I would say glow plugs or injector seals.
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: A3 Start Judder
    Dec 2015
    yorkshire
    I'm going to go take it to where I got it from tomorrow and see what they have to say
    other than this shuddering when starting
    the car drives perfectly fine no bother at all i
    it doesnt all ways happen but when it does it just starts alarm bells going in my head and id rather have it sorted before it could lead to something else.
  4. Re: A3 Start Judder
    Jan 2011
    East Kent
    Do it does this when it is cold? Or when the engine is hot?
    Previous: 2005 A3 1.9tdi SE
    2009 Audi A3 2.0tdi 138bhp SE
  5. Re: A3 Start Judder
    Dec 2007
    8 Post(s)
    Maybe anti shudder valve problem
  6. Re: A3 Start Judder
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by micheal balbrig View Post
    Doesn't that operate when you turn the engine off?
    Ian
  7. Re: A3 Start Judder
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Depends on the engine and type of ASV fitted - the older vacuum operated only type operate when ignition turned off, the later ones modulate a flap to control intake air and EGR and shut off when ignition is turned off to act as the ASV. I had one of these later types fail on me, it lost its positional reference,for want of a better term, and ultimately failed closed shutting the engine down, but gave rough running before total failure. It seems to be relatively common failure on the PD engines as they get older.
  8. Re: A3 Start Judder
    Dec 2015
    yorkshire
    Quote Originally Posted by alankru View Post
    Its very random its happened to me when cold and hot
  1. Question Judder on Start up - New Flywheel? 2007 Golf 1.9 TDI
    By golf38 in forum Golf MK5 - 2004 - 2009
    Last Post: 06-07-2016, 06:02 AM
  2. mk4 tdi cold start judder problem
    By rookie in forum Golf MK4 - 1999 - 2004
    Last Post: 04-12-2013, 07:33 PM
  3. 1.8t quattro heavy judder and shaking during start up
    By GoldieLoc in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-10-2010, 08:43 AM
  4. Golf V5 VAG COM Errors - Cold Start Judder
    By redsearich in forum Golf MK4 - 1999 - 2004
    Last Post: 08-01-2010, 01:28 AM
  5. Judder from quick start
    By ian in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-03-2007, 07:50 PM
