Thread: Replacement LED rear light advice needed
  1. Replacement LED rear light advice needed
    Jan 2015
    United Kingdom
    Morning all, I need to replace a right inner brake light cluster. The back of the old one has the part number 4G5 945 094 A as shown in the picture.
    If I trawl around the interweb I can see there is a "B" version. For example this is from Partsbase
    15 4G5945094A led tail light; right; saloon+; PR-8SK
    15 4G5945094B led tail light; right; saloon+; PR-8SL
    I know the last few digits are important to differentiate LED vs Bulb and left vs right, but does the "B" indicate if this is the part that supersedes mine, or is cosmetically different (tinted / different connector . . ..)?
    FYI I had a look through the chassis plate for the installed options as I assumed "PR-8SK" related to PR Codes.. I can see neither the two listed from PartsBase:
    PRCode: 8BP = Bi-functional headlight with gas discharge lamp
    PRCode: 8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving)
    Sorry for such a woosey question, but just want to be sure that if I spend £120 I get the right part.
    (BTW if you spotted my other post, the warranty people expect me to pay the 1/2 hour for the diagnostic and an excess on the fit. The policy exclude "bulbs and lamps" so for the sake of ~£50 and not being without my car, I can easily source and fit it myself)
  2. Re: Replacement LED rear light advice needed
    May 2014
    Bath, UK
    I think:
    8SL is North America.
    8SK is Europe.
    Or you could just ring a dealer's parts counter with your reg and ask them the part code.
  1. LED tail light replacement
    By Lyons in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 01-02-2016, 07:43 AM
  2. Important 2008- AUDI A4 S4 B8 AVANT FACELIFT 2012- REAR LED LIGHT advice sought
    By andylef in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-03-2014, 05:21 PM
  3. Reversing light bulb - can I use an LED replacement?
    By UVB in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-06-2013, 09:47 PM
  4. Replacing rear LED tail light cluster (failed LED bulb)
    By vw1967 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-06-2013, 07:29 AM
  5. Le Mans Avant Led Rear Light Bulb Replacement £58. !!
    By Furion in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-05-2013, 09:03 AM
