Thread: Rear outer led lights not working
  1. Rear outer led lights not working
    Jun 2010
    Manchester, United Kingdom, United Kingdom
    10 Post(s)
    I started a post about replacing my rear indicators with LED bulbs....but I ended up fitting standards instead because of fault codes
    Now ..... My driver side rear outer led lights will not work..... The indicator works after much fiddling but the leds do not... They do flash if I tap them hard ... So do I need a new unit?
    Background ...
    At first I thought it was the bulb holder because I saw many small connections areas had been severed because of the way I reinstalled it after I put in the new standard indicator bulb.... But this seems a deliberate design ....that the plastic inner part of the unit is constructed to server certain circuits so that this standard bulb holder works with LED rear lights....I have just picked up a new bulb holder with connections intact but I have just reinstalled it again... No joy... Do I need a new rear unit ?
    This is very frustrating because I have gone out and spent dough on a part that either was not needed or I have installed it wrongly and damaged it (again) or I need a new rear light unit!
    A6 C6 Quattro Avant 2.7TDi
    Audi A6 C7 Allroad 3.0 TFSI.
    Previous:
    Audi A6 C6 2.7TDI Le Mans.
  2. Re: Rear outer led lights not working
    46 Post(s)
    LEDs do tend to fail over time, I think some other people have had the same problem on here, you should find some information if you do a search?
    Jun 2010
    10 Post(s)
    I have done.... Most of the issues are water based ....
    Brake lights work but the rest do not .... These niggling issues do my head in
    Previous:
  1. LED rear lights on SV?
    By Erling in forum Golf SV
    Last Post: 31-03-2015, 10:28 PM
  2. Rear LED Lights
    By icebun in forum Golf MK7 - 2013 - 2019
    Last Post: 09-01-2014, 08:29 AM
  3. Saloon and estate rear lights are the same (outer ones)
    By crazy4alfa in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-09-2013, 05:11 AM
  4. Replies: 7
    Last Post: 11-08-2012, 10:13 AM
  5. led side lights and number plate lights, not working
    By adamk in forum Audi A3 - Archive Topics
    Last Post: 02-04-2008, 07:37 PM
