Thread: AUXILLARY Heating Enabled via VCDS and Green Menu.
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. AUXILLARY Heating Enabled via VCDS and Green Menu.
    Feb 2013
    Uk
    38 Post(s)
    I have enabled the Auxillary Heating via VCDS and in the green menu .
    See MMI images attached .
    however the timing is greyed out- I was hoping to use the time setting to, let fresh air into the car and thought this would work.
  2. Re: AUXILLARY Heating Enabled via VCDS and Green Menu.
    Jun 2015
    West Yorkshire
    How does this aux heater work. I have something on my Q7 about heater but its not displayed like that in the menu. Its just in AC sectiom and simply says a yes or no.
    Sent from my SM-G900F using Tapatalk
  3. Re: AUXILLARY Heating Enabled via VCDS and Green Menu.
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    If your Q7's are pretty much the same as a Toureg, you will have a Webasto diesel combustion heater tucked up behind the drivers (IIRC) wheel arch. this has a small electric circulating pump and by the looks of your MMI display you can configure it to come in to defrost the car in the morning etc. You might have a sticker in the engine bay giving details of the webasto, next to the sticker that gives the AC refrigerant charge etc. Maybe on Shab's Q7 the yes or no is just giving you the option to switch it off, rather than the Econ button on a lot of other cars fitted with this heater.
    Dont know much more specific to a Q7 or MMI set up - never played with one.
  4. Re: AUXILLARY Heating Enabled via VCDS and Green Menu.
    Feb 2013
    Uk
    38 Post(s)
    Quote Originally Posted by Rob69 View Post
    my car is an Audi A6 (used to have a q7 -hence user name) - I do not have auxilary heating / webasto heater- I have just enabled the options via VCDS and Green Menu on my A6 and I was hoping to at least be able to set the timers to let the fans run and let outside air in to the vehicle in the summer (don't want to leave windows open when parked all day).
    as per my image the "Timers" are greyed out - So I can't select the times etc - i would like some help on how to enable the timers
  5. Re: AUXILLARY Heating Enabled via VCDS and Green Menu.
    46 Post(s)
    To enable the timers you need the whole retrofit. Enabling it without the required hardware doesn't really benefit or have a purpose.
  6. Re: AUXILLARY Heating Enabled via VCDS and Green Menu.
    Feb 2013
    Uk
    38 Post(s)
    Quote Originally Posted by Chris View Post
    many thanks chris - will send you a PM in a couple of minutes.
  7. Re: AUXILLARY Heating Enabled via VCDS and Green Menu.
    Nov 2010
    104 Post(s)
    That'll be why it's in the A6 forum and the car looks like a car in the MMI display then !! silly me
  8. Re: AUXILLARY Heating Enabled via VCDS and Green Menu.
    Feb 2013
    Uk
    38 Post(s)
    Chris , PM sent
  9. Re: AUXILLARY Heating Enabled via VCDS and Green Menu.
    Jun 2015
    West Yorkshire
    Yes I have that heater. It has an exhaust outlet on passenger front underside of car and does generate fumes when the car is initially turned on.
    So on the A6 how does this heater work and how does it het activated? Assume car needs to be on
  10. Re: AUXILLARY Heating Enabled via VCDS and Green Menu.
    Feb 2013
    Uk
    38 Post(s)
    I have now enabled the timers - which lets you set the time duration of the "Heat" , date and start time , also the symbol lights up by the rotary dial that controls the speed of the fan when it's activated - I know i won't get "Heat" because the webasto heater is not fitted - its ventilation I'm after
  1. Question No heating coming up! just cold air only. VCDS scan results attached. Please help!
    By want in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 20-10-2015, 10:29 PM
  2. Replies: 4
    Last Post: 09-06-2015, 10:11 AM
  3. 2010 A6 with basic parking - enabled visual display with VCDS!
    By SiliconS in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-05-2011, 05:42 PM
  4. Residual heat enabled
    By ScottyUK in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-01-2011, 10:43 PM
  5. Conformation of alarm enabled
    By 73kingstonroad in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-08-2009, 07:54 AM
