Thread: LT35 Diff replacement
  1. LT35 Diff replacement
    Aug 2008
    Hinckley, Leicestershire
    Hi folks
    Looking for a bit of advice regarding replacing the diff on my LT35. It's a 2006 model, 2.5TDI with ABS and ABD.
    The diff started whining a few months ago and has been steadily getting worse since. Of course I have checked the oil level and all is good so it looks like I'm going to need a replacement sooner or later and wondered whether anyone on here had attempted such a replacement and could give me some pointers to look out for before I attempt the process.
    I would be looking to obtain a second hand diff from a breakers or perhaps even a complete rear axle and would be grateful for comment sas to which is the easier/cheaper option.
  2. Re: LT35 Diff replacement
    Pembrokeshire
    22 Post(s)
    complete rear axle, much much easier. iirc its a spring over axle arrangement, so the axle simply un bolts and drops down. are you sure its the diff thats whining though and not either a wheel bearing or even a rear tyre.
    1 1 0
  3. Re: LT35 Diff replacement
    Aug 2008
    Yeah, thought as much. Thanks for the advice Zollaf.
  1. Diff WHINE A4 S line 1.8T - can't source a correct replacement box help
    By gem4lee09 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-10-2015, 03:03 PM
  2. Topping up diff
    By faithsmummy in forum A8 - S8 - V8
    Last Post: 06-05-2013, 10:11 AM
  3. LT35 Timing/pump belt replacement????
    By boisty in forum The Commercial Range
    Last Post: 07-09-2011, 12:56 AM
  4. rear diff seal replacement
    By andy_garm in forum 80 - 90
    Last Post: 14-05-2008, 01:45 AM
  5. Knocking Diff???
    By stegvht in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 25-04-2008, 10:49 PM
