Thread: Front Wheel Bearing - Bit of dirt
Results 1 to 8 of 8
  1. Front Wheel Bearing - Bit of dirt
    Sep 2007
    Plymouth
    Sorry to mention a non related VAG brand...but I've been tasked to change a front wheel bearing on my other halfs' Vauxhall Corsa!
    Anyone had any experience of these? Easy or difficult, does it need a press?
    (I drive an A6)
  2. Re: Front Wheel Bearing - Bit of dirt
    Feb 2007
    Nottingham
    Quote Originally Posted by Clinterous View Post
    (I drive an A6)
    No car really NEEDS a press if you know what you're doing with a wheel bearing
    You may think I'm being helpful yet sarcastic, this is only because I feel I need to help you to help yourself in the future
  3. Re: Front Wheel Bearing - Bit of dirt
    Sep 2007
    Plymouth
    Thanks.
    Armed with that, I have belief and will proceed forthwith!
  4. Re: Front Wheel Bearing - Bit of dirt
    Quote Originally Posted by Captain Answer View Post
    I've done both front bearings on my A6 and it definately needs a press, the only thing holding the bearings in is their tight (interference) fit and it takes a LOT of pressure to get the old ones out, and a fair amount to get the new ones in.
  5. Re: Front Wheel Bearing - Bit of dirt
    Mar 2008
    High Wycombe
    When I've done wheel bearings in the past, I've taken the bearing carriers (hub carriers) out, taken it down the road to my friendly neighbourhood garage, and paid him £10 to press out the old bearings and press in the new ones.
    You need to find a garage that will do this, as some will only do the whole job.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  6. Re: Front Wheel Bearing - Bit of dirt
    Quote Originally Posted by NickPicks View Post
    Exactly what I did mate, currently looking at making my own press using a bottle jack and weight bench frame lol
  7. Re: Front Wheel Bearing - Bit of dirt
    My sincere apologies Captain, just done one of my front bearings with a lump hammer, some large sockets and a chisel, although it took some doing it can be done!
    However unless (as you say) you know what you're doing I would recommend using a press if possible, especially for the A6 front!
  8. Re: Front Wheel Bearing - Bit of dirt
    Feb 2007
    Nottingham
    It does make it easier however and I do tend to get them pressed for timesake. Some of the bearing puller kits are quite good apparently though i've never used one myself
  1. A6 replacing wheel bearing - anyone done this?
    By Niall76 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-05-2009, 09:58 PM
  2. a4 quattro front wheel bearing
    By sbt in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-10-2007, 05:05 PM
  3. Wheel bearing???
    By HMIT in forum Golf MK4 - 1999 - 2004
    Last Post: 03-09-2007, 06:06 PM
  4. Front Wheel Bearing replacement
    By tornadored7 in forum Archive posts
    Last Post: 30-08-2007, 09:05 PM
  5. Audi A4 wheel bearing
    By MickM in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-07-2007, 01:22 PM
