Thread: Boot does not open on VW Bora
Results 1 to 10 of 10
  1. Boot does not open on VW Bora
    Jul 2007
    Help needed boot is not opening with remote key fob on my VW bora any ideas?
  2. Re: Boot does not open on VW Bora
    Aug 2011
    Meath
    Does it open at all?
  3. Re: Boot does not open on VW Bora
    Oct 2015
    GB
    What year in car??
    Sent from my SM-A300FU using Tapatalk
  4. Re: Boot does not open on VW Bora
    Jul 2007
    No it does not open at all
  5. Re: Boot does not open on VW Bora
    Jul 2007
    Car is 115 TDI 2001
  6. Re: Boot does not open on VW Bora
    Aug 2011
    Meath
    You need to drop the back seats and crawl in with a torch. take off the cover and manually open the boot, it's likely the solenoid has gone but you can get it open and repaired without damaging anything
  7. Re: Boot does not open on VW Bora
    Jul 2007
    Thanks how much am I looking at to get it repaired?
  8. Re: Boot does not open on VW Bora
    Pembrokeshire
    22 Post(s)
    press and hold the boot unlock button for at least a good few seconds...
  9. Re: Boot does not open on VW Bora
    Aug 2011
    Meath
    It could be the switch or actuator neither are expensive maybe 30 notes less from a breaker
  10. Re: Boot does not open on VW Bora
    7 Post(s)
    This is quite a common problem.
    The insulation on the wires in the loom to the boot lid where it folds over on itself breaks down and causes a short circuit. You most likely need to open up the loom where it folds and repair the exposed wires and insulation.
    You should still be able to put the key blade in the lock to get in but if that doesn't work you can indeed crawl in from with the back seats folded.
  1. Can't open boot
    By Jayc530 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-02-2011, 09:22 PM
  2. Please Help Boot will not open
    By boilerchicken in forum Polo - Derby - Lupo - Fox
    Last Post: 03-11-2009, 09:46 AM
  3. Can't open boot
    By cozican in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-08-2009, 11:03 AM
  4. Cant open boot - help
    By mondeonam in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-03-2009, 01:07 PM
  5. bora boot lid won't open
    By frednemm in forum Bora - 1998 - 2005
    Last Post: 24-02-2009, 06:07 PM
