Thread: Newbie-Audi A6 2.0tdi 2008 S-line power issues
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. Newbie-Audi A6 2.0tdi 2008 S-line power issues
    Dec 2015
    Blackburn
    Hi everyone. Im sorry if this has been covered elsewhere but im new to this. I have been looking at different forums but cant seem to get an answer. I have a 2008 audi a6 2.0tdi 140bhp. Ive owned the car 6 months and all has been well.
    Very recently the car lacks power between 1500rpm to 2000rpm im all gears.it does not do this all the time it just has its moments on occasions. When this does happen and im on the motorway in.6th gear the car loses all power and struggles to get past 3000rpm or 80mph.i travel 60miles a day on the motorway.
    I have recently had a full service complete with fuel filter, oil filter, air filter changed..ive also had the forte cleaning treatment too. Please can someone point me in the right direction or recommend a good audi specialist near blackburn. No lights have come on the dashboard either. The car is on 125k and full audi dealership history. I hear there are some very knowledgeble blokes on here who may be help
    Thanks a million
    Kal
  2. Re: Newbie-Audi A6 2.0tdi 2008 S-line power issues
    Mar 2011
    Clitheroe, England
    11 Post(s)
    I can't provide answers or even suggestions as I'm just not one of the mechanically-minded members on here, but I can offer to scan your car for you with VCDS. This will give you some diagnostic results to post up here, that the more knowledgeable members can use to help pin down possible causes. It'll also save you forking out £100 odd quid for Audi to do basically the same thing. I'm just outside Clitheroe. PM me if you're interested & I'll let you have my contact details.
    Cheers,
    Paul.
    The Only Way Is A6!
    1 1 0
  3. Re: Newbie-Audi A6 2.0tdi 2008 S-line power issues
    Dec 2015
    Blackburn
    Hello,
    Thanks to Brycie got the codes from car. Top bloke. Below is the engine fault. There was loads of other data but the engine fault is as below. Couldnt figure out how to get all the data on here
    If any one could shed some light would appreciate it.
    1 Fault Found:
    000665 - Boost Pressure Regulation
    ************** P0299 - 000 - Control Range Not Reached - Intermittent
    ************ Freeze Frame:
    ******************* Fault Status: 00100000
    ******************* Fault Priority: 2
    ******************* Fault Frequency: 6
    ******************* Reset counter: 255
    ******************* Mileage: 199640 km
    ******************* Time Indication: 0
    ******************* Date: 2015.11.28
    ******************* Time: 20:07:45
    ******************* RPM: 2142 /min
    ******************* Speed: 107.0 km/h
    ******************* Load: 50.2 %
    ******************* Voltage: 13.53 V
    ******************* Bin. Bits: 00101000
    ******************* Absolute Pres.: 2305.2 mbar
    ******************* Absolute Pres.: 1825.8 mbar
    Readiness: 0 0 0 0 0
  4. Re: Newbie-Audi A6 2.0tdi 2008 S-line power issues
    131 Post(s)
    1973 Post(s)
    Actually I was wrong, it is an under boost problem, not over boost. On the BLB/BRE engine I have seen this caused by a broken wire to the N75 valve due to the wiring being too short, a leak in the vacuum system (highly likely) or a problem inside the turbo making the adjuster ring stick but this is the least likely with this code, that problem would normally give an over boost code.
  5. Re: Newbie-Audi A6 2.0tdi 2008 S-line power issues
    Dec 2015
    Blackburn
    Thanks for looking at the issue crasher. Can you describe the N75 value or if you have a picture? When you say vaccum leak, is this just checking the hoses for splits. sorry im a complete novice.
    If you or any one can point me to another thread which has the info or if someone can recommend a decent audi specialist around the blackburn area. i dont mind travelling as long as the job is done properly.
  6. Re: Newbie-Audi A6 2.0tdi 2008 S-line power issues
    131 Post(s)
    1973 Post(s)
    The wiring problem I have had twice, the unit has to be accessed from below the car after removing the lower cover so the car needs to be up in the air. The start point for the vacuum is the small take off hose from the vacuum pumps feed pipe to the servo, apply a vacuum to this hose and you should not be able to draw air through it. I have one of these on a lift (we are preparing it for sale) but we are just off for the works Christmas dinner, I will try and take a picture next Tuesday.
  7. Re: Newbie-Audi A6 2.0tdi 2008 S-line power issues
    Dec 2015
    Blackburn
    Thanks mate. In the meantime i will take to a garage on weekend to see if they can find it and get it checked out.
    Enjoy your meal.
  8. Re: Newbie-Audi A6 2.0tdi 2008 S-line power issues
    131 Post(s)
    1973 Post(s)
  9. Re: Newbie-Audi A6 2.0tdi 2008 S-line power issues
    Sep 2010
    ipswich,uk
    FORCETOC__
    == 16683/P0299/000665 - Boost Pressure Regulation: Control Range Not Reached ==
    ==== Possible Symptoms ====
    * Reduced Power Output
    * Limp Mode
    ==== Possible Causes ====
    * Hoses/Pipes incorrect connected, disconnected or leaking
    * Charger Pressure Control defective
    * Turbocharger faulty
    * Diverter Valve faulty
    ==== Possible Solutions ====
    * Check Hoses/Pipes to/between Components
    * Check / Clean / Replace Charge Pressure Control
    * Check Turbocharger
    * Check Diverter Valve
    ==== Special Notes ====
    * If the Turbocharger is faulty due to mechanical / internal problems or the exhaust system is restricted (typically the Catalyst) this fault may be the end result.
    A6 Avant 2.L BRE 2008,
  10. Re: Newbie-Audi A6 2.0tdi 2008 S-line power issues
    Dec 2015
    Blackburn
    Thanks mate for the info. Just to add cars been running fine since it last occurred. Im sure it wont be long before it happens again. Having said that does it rule about any or the above?
    Crasher seems as though you had a good day yesterday lol
  1. Question Newbie help!! Audi A4 2.0TDI S-Line - MMI software upgrade
    By trebor2812 in forum In Car Entertainment
    Last Post: 11-04-2014, 01:22 PM
  2. Audi A6 2.0tdi sline 2008 automatic issues
    By beanhead1979 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-09-2013, 01:55 AM
  3. 2008 S-Line Avant 2.0TDI suspension
    By IamRhino in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-11-2011, 07:07 PM
  4. 2008 A4 S-line 2.0t Headlight Issues
    By a4driver2008 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-02-2009, 09:52 PM
  5. 2008 Audi A4 S Line TDI Auto - loss of power
    By Tony Bajcer in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-08-2008, 04:39 PM
