Thread: Few lights on the dash flashing
  1. Few lights on the dash flashing
    Oct 2015
    Ivybridge, Devon
    Hello all
    The other half was driving the car this morning and while on a dual carriageway at 70, she says the ABS light came on and the coil came on and it was flashing, all acceleration lost and the car wont rev, just sits at idle and pulls along at about 10mph, luckily She rang and I told her to turn the car off and on which solved the problem and got her home, anyway plugged in VCDS when she got in and pulled the following codes out, I know I can ignore the imobilisor and the sterio codes but the other two I would Love some info on thanks in advance
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    Thursday,17,December,2015,15:23:03:62939
    Chassis Type: 4B (4B - Audi A6 C5 (1998 > 2006))
    Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
    75 76 77
    VIN: WAUZZZ4B32N039746
    Address 01: Engine Labels: 038-906-019-AVF.lbl
    Part No: 038 906 019 GF
    Component: 1,9l R4 EDC G000SG 1434
    Coding: 00002
    Shop #: WSC 02325
    VCID: 61C9430FEBBC7116FBD-49D8
    WAUZZZ4B32N039746 AUZ7Z0A1953272
    2 Faults Found:
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-00 -
    18047 - Accelerator Position Sensor 1/2 (G79/G185)
    P1639 - 35-10 - Implausible Signal - Intermittent
    Readiness: 0 0 X X X
    Address 03: ABS Brakes Labels: 4B0-614-517.lbl
    Part No: 4B0 614 517 G
    Component: ABS/ESP front 1728
    Coding: 06255
    Shop #: WSC 02325
    VCID: 2541171FBF14DD36C75-5072
    1 Fault Found:
    01314 - Engine Control Module
    79-10 - Please Check Fault Codes - Intermittent
    Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
    Part No: 4B0 959 655 M
    Component: Airbag 8.4E 3003
    Coding: 0001106
    Shop #: WSC 02325 785 00200
    VCID: 3A7BD46376AA42CE9A7-5072
    No fault code found.
    Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
    Part No: 4B0 920 981 J
    Component: KOMBI+WEGFAHRS. VDO D07
    Coding: 00440
    Shop #: WSC 00001
    VCID: 2D51EF3FE7E4E5760F5-5072
    1 Fault Found:
    01304 - Radio
    49-00 - No Communications
  2. Re: Few lights on the dash flashing
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    I guess the problem is: P-1639 Accelerator Position Sensor. Start by checking\clean the electrical connections. Delete all of the fault codes and do a test drive and check which fault code returns
  3. Re: Few lights on the dash flashing
    Oct 2005
    18047/P1639/005689 - Ross-Tech Wiki - As the man above says, this is the code you need to address.
  4. Re: Few lights on the dash flashing
    133 Post(s)
    1986 Post(s)
    This is often due to water getting into the ECU box and causing corrosion to the plug terminals below the ECU. This is a Superb but it is much the same, you can see the damage to the pin in the orange plug.
    0 2 0
  1. Replies: 3
    Last Post: 19-02-2015, 11:03 AM
  2. Question Flashing Car Lights On Dash
    By motionpotion in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-07-2014, 06:52 PM
  3. ABS, Glow plug, Traction control lights Flashing and no brake lights
    By bbq365 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-02-2011, 06:15 PM
  4. Please Help Engine not turning off and lights flashing on the dash
    By sadaqt in forum Golf MK3 - 1993 - 1999
    Last Post: 14-09-2010, 11:22 PM
  5. passat flashing dash lights
    By minty0_10 in forum Passat - Archive Topics
    Last Post: 25-11-2006, 11:18 PM
