heres my problem changed thermostat / expansion tank and cap / new heater matrix /new rad /temp sensor / water pump changed last year here goes can get red hot air out of heaters with reving the car and cap of expansion tank so no air locks top and bottom rad hose hot drive it with cap back on heaters blow cold after a shortish drive expansion tank r next morning even cold loads of air comes out and coolant rises is this classic hg gone last owner changed water pump rad and thermostat help please at wits end with this car and to make thing worse got g201 error code no abs lights on just can not turn on esp as esplight on
