Thread: 2.0 TDI balancer shaft replacement
Page 4 of 4 FirstFirst ... 234
Results 31 to 33 of 33
  1. Re: 2.0 TDI balancer shaft replacement
    #31
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by SteveHam View Post
    Thanks for the advice DMitch16 - and apologies for the really slow reply. I have finally obtained a renewed balance shaft from KMB (had a few courier problems), and now I'm ready to install.
    The assembly is all gear driven, and I have the shaft locking tool. Also took a while to obtain but its finally here too...
    Question is: does this type need to be installed at TDC with the crank locking tool? I have read conflicting posts that it doesn't.... I've gone this far and would hate to have dramas at the 11th hour!
    Steve
    Yes I always lock the timing and have done this job several times now. Cam lock pins are difficult to engage fully into the head, must go back into the machined head holes, due to tight tolerances and crank lock tends to be the opposite with slightly too much tolerance so important to double check the timing.
    My view is that when the unit is refitted the balance shafts sit flat due to their weight distribution and as locked by the alignment block there needs to be a second reference point for the counter balance of the crankshaft torsional forces. Without the timing locked and the balance shaft alignment preserved in the unit these torsional forces which act at certain times during the crankshaft rotation, will not be countered at the right times and essentially the balancing process compromised.
    Have I sent you, or do you have, the VW workshop process for this job? If not PM me your email address and I'll send it over on PDF.
    Mad Mitch
  2. Re: 2.0 TDI balancer shaft replacement
    #32
    Jul 2020
    Melbourne, Australia
    great - thanks Mitch. I'll pm you now. I'll jump online and get a set of the crank locks and also new bolts for the assembly as I've heard they are important to change also...
  3. Re: 2.0 TDI balancer shaft replacement
    #33
    Apr 2021
    bournemouth
    Hi Gaz,
    Could you advise if the balance shaft change is the same on a A6 2007 as the Passat? The guide you post on forums I believe is for the PASSAT? I can not find an A6 guide anywhere.
    I am purchasing the A6 this weekend with. 148k, full service history, no history of balance shaft being done. Should I stay away from it?
  1. Please Help Balancer Shaft Assembly
    By TaximanWsM in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-09-2013, 12:26 PM
  2. Balancer Shaft Query
    By coolraj003 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-09-2012, 06:55 PM
  3. Balancer Shaft Problems ?
    By neovw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-09-2012, 08:24 AM
  4. Attention Audi A4 oil pump / balancer shaft
    By Don't like Audi in forum Chat - Anything with wheels
    Last Post: 03-02-2012, 09:56 PM
  5. Oil pump balancer shaft
    By mission66 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-08-2010, 08:10 AM
