Thread: Sat Nav Retrofit
Results 1 to 10 of 20
  1. Sat Nav Retrofit
    Nov 2015
    Middlesbrough
    Hey everyone,
    I'm up to doing a nav retrofit as I recently purchased a 2005 A6 with MMI 2g-High.
    I've found that the nav module I need, that being P/N 4E0 919 887 (C)
    I'm having an issue finding which cables I'll need to wire it up however, there seems to be so many. Does anyone have any part numbers or locations to buy them (that don't cost the earth)?
    Thanks in Advance
    Callum
  2. Re: Sat Nav Retrofit
    Nov 2015
    Middlesbrough
    AUDI MMI2G ADAPTOR A4 A5 A6 A8 Q5 Q7 FIBRE OPTIC PLUG & PLAY WIRING HARNESS MOST | eBay
    Quick update, found this whilst searching for a different retrofit: is this suitable?
  3. Re: Sat Nav Retrofit
    May 2014
    Darlington
    78 Post(s)
    Yes, that would work for the wiring side, you just need to fit the GPS antenna. If you need any help with the retrofit give me a shout I'm over in Darlington can also help with VCDS coding etc.
  4. Re: Sat Nav Retrofit
    Nov 2015
    Middlesbrough
    I appreciate that offer. I will require help with the VCDS as I don't have a laptop! My car has the shark fin on the roof so I assume it has the GPS antenna wire somewhere?
  5. Re: Sat Nav Retrofit
    May 2014
    Darlington
    78 Post(s)
    It should have a blue fakra connector near the shark fin, but there were BT only shark fin's so you need to take a look to see if you can see a blue connector, you will then need fakra cable to connect from the blue connector to the back of the nav unit, I can make them if you don have one.
    Do you have an Avant or saloon?
  6. Re: Sat Nav Retrofit
    Nov 2015
    Middlesbrough
    It's a saloon. Where can one find the fakra extension so you don't have to go to the trouble of making one?
    By the shark fin, does this mean in the headlining or is it in the C Pillars?
  7. Re: Sat Nav Retrofit
    May 2014
    Darlington
    78 Post(s)
    You could try ebay, or kufatec.
  8. Re: Sat Nav Retrofit
    Nov 2015
    Middlesbrough
    Do I need female - female, and if so, roughly how long? Will 1M do?
    I apologise for all the questions
  9. Re: Sat Nav Retrofit
    Nov 2015
    Middlesbrough
  10. Re: Sat Nav Retrofit
    May 2014
    Darlington
    78 Post(s)
    That all, but I would check the sharks fin first before buying.
  1. sat nav retrofit instructions - help
    By s7gpt in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-11-2012, 10:52 PM
  2. audi q5 sat nav retrofit ?
    By kennyjmac in forum Q5
    Last Post: 25-04-2011, 03:32 PM
  3. RNS-E Sat Nav Retrofit HELP!
    By scooper06 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-09-2009, 03:54 PM
  4. Retrofit sat nav
    By mdjsa3 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-05-2009, 06:29 PM
  5. B5 Sat Nav Retrofit
    By JonathanK in forum Passat - Archive Topics
    Last Post: 31-12-2006, 04:59 PM
