Thread: 3.0 TDI - Fuel filter check
Results 1 to 9 of 9
  1. 3.0 TDI - Fuel filter check
    Dec 2015
    Apparently the fuel filter can be checked visually for possible signs of contamination. Im my case this is for oil, since i have a suspected faulty injector. Is this simply a case of removing the split pin on the circular return line fitting at the top of the filter, and pulling it off to have a look? If so will this trigger any EML/MIL lights, or codes, or air locks? Will it reseal ok afterwards? WG.
  2. Re: 3.0 TDI - Fuel filter check
    Sep 2011
    Lurking over a keyboard ...
    Chris's guide on fuel filter change, Link- VW Audi Forum - The #1 VW Group Community
    Yes you can reuse valve.
    If you do drain FF into a container I'd refill it on refitting, this will make starting easier and reduce impact of air in fuel system.
    IIRC I didn't get a EML/MIL as refilled FF, if you do happen to get one after x starts/detection fault is not re-occurring it should go away IIRC.
    You should be able to see a date stamp on FF, I'd probably replace it if doing what your doing unless already newish/no contamination in contents.
    I got genuine VAG ones off ebay cheaply for last 2 changes.
  3. Re: 3.0 TDI - Fuel filter check
    Dec 2015
    It was Chris's guide that gave me the idea, that perhaps since the only way oil is likely to enter the FF is via the return line and the fact that oil will float due to its lower specific gravity, any oil might easily show in the hole just under the return valve. That would save all the trouble of removal, testing in a glass etc. Not as thorough, but easy peasy.
    I'll have a look on eBay, thanks for the info.
  4. Re: 3.0 TDI - Fuel filter check
    Sep 2011
    Indeed you may well see it through the return valve hole , so that's way I said "If you do drain FF..." .
  5. Re: 3.0 TDI - Fuel filter check
    Dec 2015
    I might give that a go then - thanks Gup' .
  6. Re: 3.0 TDI - Fuel filter check
    Sep 2011
    No worries .
    The injection system is self bleeding of air from what I read in the official VAG service guide.
    Like I said in the PM if you don't have VCDS to switch fuel relay on cycling the ignition up to cranking and then back, then removing key and reinserting should make the relay kick in again.
  7. Re: 3.0 TDI - Fuel filter check
    Dec 2015
    That's great, thanks again!
  8. Re: 3.0 TDI - Fuel filter check
    Jul 2007
    glasgow
    35 Post(s)
    With the colder weather, any water in filter will freeze. There is no water drain on the filter, I change mine every 20,000
    I simply fill the filter up with clean diesel, and refit. If you get Mann filters ( I do ) then they come with seals, replace them
    Easy enough job
    2 1 0
  9. Re: 3.0 TDI - Fuel filter check
    Mar 2013
    Lincolnshire
    You can always fill the new filter with injector cleaner too for that initial start
    A6 2008 57 Reg 2.7TDi SE Tiptronic Avant Quattro
  1. tdi fuel filter
    By wedge in forum 80 - 90
    Last Post: 14-11-2013, 11:22 AM
  2. Question What is the best way to prime a 2.0 tdi fuel system after changing fuel filter?
    By battmiceter in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-10-2012, 09:40 PM
  3. Please Help 80 tdi fuel filter
    By dave 80 in forum 80 - 90
    Last Post: 07-04-2010, 04:08 PM
  4. Fuel Filter 2.5 TDi
    By jimat57 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-04-2008, 05:57 PM
  5. Bio-Fuel - check! V8 - check! 1000 bhp - check!.....
    By Sam in forum Chat - Anything with wheels
    Last Post: 03-12-2007, 04:29 PM
