Thread: Vw powerboat with 3.0tdi v6 with vcds codes need help with a fix
  1. Vw powerboat with 3.0tdi v6 with vcds codes need help with a fix
    Nov 2015
    essex england
    Hi I own a VW 3.0 TDI V6 Boat with engine code BSP ( Same as BKS in VW Touareg ) I need a genius !! ( please treat as a car the boat makes no difference)
    basic history is only owned for 3 months and it was always hard to start after it had been left for 48hrs + , once started it will start on the button all day long .( doesn't use glow plugs) .
    one afternoon whilst on boat it just stopped as if key had been turned off - hasn't started since .
    A mate loaned me his VCDS LEAD and LAPTOP and this is what faults are stored but I don't know what they mean or what is likely to be wrong can you help ? ( couldn't down load pictures of vcds screens taken on my mobile as files too large so typed out info
    4 faults found
    004501- fuel pressure regulator valve (N276)
    P1195 -001-Open or short to ground -MIL ON
    Freeze frame
    fault status 11100001
    fault priority 0
    fault frequency 1
    time indication 0
    freeze frame
    rpm 0/min
    torque 0.0 nm
    speed 0.0km/h
    voltage 12.31v
    pressure 0.0bar
    duty cycle 0.4%
    013128 -control circuit for turbocharger 1 ( j724)
    P3348 -003-electrical malfunction - MIL ON
    freeze frame
    fault status 11100011
    fault priority 0
    fault frequency 1
    time indication 0
    freeze frame
    rpm 0/min
    torque 0.0 nm
    speed 0.0km/h
    temperature 10.8 c
    duty cycle 95.5%
    voltage 12.31v
    duty cycle 0.4 %
    004737 - VALVE FOR FUEL METERING (N290)
    P1281-001- short to ground
    freeze frame
    fault status 01100001
    fault priority 0
    fault frequency 1
    time indication 0
    freeze frame
    rpm 0/min
    torque 0.0 nm
    speed 0.0kmh
    duty cycle 1.0%
    voltage 12.31v
    pressure 0.0 bar
    duty cycle 0.4%
    P3348 -009-electrical malfunction
    freeze frame
    fault priority 0
    fault frequency 1
    time indication 0
    freeze frame
    rpm 0/min
    torque 0.0 nm
    speed 0.0km/h
    temperature 10.8 c
    duty cycle 95.5%
    voltage 12.31v
    duty cycle 0.4 %
    readiness 1 2 X 0 X
    I have cleared the faults by using VCDS and as soon as the ignition is switched on they all come straight back
    Can any body help in anyway or explain what to check or if based near Essex can you come and take a look ( VW Marine dealers not easy to obtain ) , please treat this fault as a car the boat makes no difference .
    pulling my hair out now
    many thanks in advance for any help / advice given
    Stuart
  2. Re: Vw powerboat with 3.0tdi v6 with vcds codes need help with a fix
    Oct 2005
    Welcome to VWAF
    With the 2.7 TDI V6 P1195 or P1281 indicate a wiring loom problem. I suspect (but cannot be sure) that you've got something similar.
    P3348 also suggests wiring see this link on the Ross Tech Wiki for more info >>> 19804/P3348/013128 - Ross-Tech Wiki
  1. Brake Pedal Monitoring fault on VCDS-Lite how to fix ?
    By edzha90 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-10-2014, 01:55 AM
  2. VCDS codes And logs help
    By golfmk4ATD in forum VCDS - Help Requests
    Last Post: 23-05-2014, 10:46 AM
  3. VCDS error codes
    By szladob in forum VCDS - General Questions
    Last Post: 05-04-2014, 11:09 PM
  4. How to fix VAGCOM codes
    By PETER G in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-09-2009, 05:56 PM
  5. Vag-Com error codes, any ideas for fix?
    By abbeyhouse in forum Archive posts
    Last Post: 05-06-2007, 11:30 PM
