Thread: Lucas or Teves Calipers
  1. Lucas or Teves Calipers
    Jun 2013
    Derbyshire
    Car has just started warning me I need new brake pads and instead of having to pay £399 to audi I was going to sort them myself, that is until I found there are a silly amout of pads and discs to choose from on EuroCarParts....
    Rang TPS but they wanted £240
    I've found the PR code 1LA which leads me to either of these discs:
    http://www.eurocarparts.com/ecp/c/Au...isc/?104442088
    http://www.eurocarparts.com/ecp/c/Au...c/?104448219&1
    but none of the pads list 1LA as a pr code so i have no idea which set of pads it might be....The only pads on ECP that don't refer to 345mm diameter discs have the PR code 1LT None list 1LA
    Can any one tell me if these are Teves or Lucas ones? Can anyone point me to how i find the right pads for these callipers?
    (A4 2011 3.0 TDi V6 Black Edition)
  2. Re: Lucas or Teves Calipers
    glasgow
    35 Post(s)
    The 1LA code should give the disc size you need and therefore the pad size.
    The links you provide doesn't tell us the size difference between makes.
  3. Re: Lucas or Teves Calipers
    Jun 2013
    Derbyshire
    Discs are 320mm if that helps.
  4. Re: Lucas or Teves Calipers
    Dec 2008
    @classiccarguru1
    I've just gone GENUINE Audi for a brake "set"
    GENUINE discs x 4
    GENUINE Front & Rear pads
    all new caliper and slider bolts, clips and backplates.
    In one kit for £310 inc VAT
    Not worth bothering going aftermarket.
  5. Re: Lucas or Teves Calipers
    Jun 2013
    Derbyshire
    That's interesting Darren, I rang Audi first to get a bench mark price. They wanted £399 for fully fitted Front Discs and pads. Or just to supply front discs and pads the price was £322. (both inc vat)
  6. Re: Lucas or Teves Calipers
    Jun 2013
    Derbyshire
    Just in case anyone wants to know the outcome of this I've just stripped the callipers off to measure up the pads. Mine has TRW callipers on it.
    Looking a GSF, they list pads with the PR code 1LA which matches my PR code.
    FRONT BRAKE PAD SET 642VG0021
    All the measurements match up to my pads too.
    So for font discs and pad it comes to £154 including their 25% web offer discount at the moment. far better than the £322 Audi quoted me for just front pads & discs.
    Will order them and see if it all goes to plan!
  1. Question Golf 1.9 TDI 2002 - Alternator - Bosch vs Lucas vs Valeo vs Hella
    By tomhass in forum Golf MK4 - 1999 - 2004
    Last Post: 20-08-2023, 11:10 AM
  2. Lucas upper cylinder lubricant and injector cleaner
    By promar in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-04-2011, 04:15 PM
  3. Calipers
    By leonp in forum Early Passat Forum - Pre 97
    Last Post: 13-04-2009, 10:27 PM
  4. Question Easy way to tell if it's Lucas or ATE brake system
    By danclyon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-03-2009, 10:32 PM
  5. Lucas brake issue with S4
    By pmwilbur in forum Archive posts
    Last Post: 08-01-2008, 04:07 AM
