Thread: Spongy Brakes
  1. Unhappy Spongy Brakes
    May 2009
    Hi guys,
    I changed the front discs and pads on my 01 gti 115bhp today. After I changed them my pedals like a sponge when you push it down. When the cars off its nice and hard but once started its spongy. The car stops fine but the pedal was never spongy before. I've changed discs and pads on many cars over the years without a problem. Not sure how I could have got air into the system doing this and I hope I havent done more serious damage . Any ideas, thanks in advance
    Mike
  2. Re: Spongy Brakes
    Oct 2015
    GB
    Air bubbles, bleed it with the old fashion kit and also a pressure pump on the resivour that should do it but top up with fresh fluid
    Sent from my SM-A300FU using Tapatalk
  3. Re: Spongy Brakes
    May 2009
    yes mate I'm going to buy an eezibleed kit tomorrow and bleed them, just strange how air got into the system this time and never has before
  4. Re: Spongy Brakes
    Pembrokeshire
    22 Post(s)
    you can't get air in by changing pads. did you loosen the bleed nipple when you pushed the piston back. if you did, great, if not then you may have pushed muck back into the abs pump or master cylinder. other option is the pads just need bedding in, but this is more usual when you havn't changed the discs and the pads have to wear to the shape of the old worn discs.
  1. spongy brakes
    By mbev51 in forum Golf MK5 - 2004 - 2009
    Last Post: 02-05-2010, 05:29 PM
  2. Spongy brakes 03 S6
    By nick.henderson in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-03-2010, 08:15 PM
  3. Audi S4 Spongy Brakes
    By wadi110 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-08-2008, 08:52 PM
  4. spongy brakes need help please
    By frankmcc in forum Touran - Sharan - Caravelle
    Last Post: 04-06-2008, 02:28 PM
  5. Spongy brakes on start up
    By fozzie in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 10-01-2008, 05:29 PM
