Thread: Please Help! Cruise Control Retrofit Won't Work
Results 1 to 10 of 18
  1. Exclamation Please Help! Cruise Control Retrofit Won't Work
    Oct 2012
    Birmingham
    Hey,
    So I recently moved from a C6 to a B7 and was missing the cruise control from the previous one so I decided to retrofit.
    Went through all the hassle, got the tools, installed it and the clutch switch wasn't working.
    Changed the clutch switch today and it is still not working!!!!!
    Really driving me crazy!
    All the values change when I press the brakes, clutch, turn the cruise on/off, press the buttons and move it up and down. - checked
    The value in steering wheel is correct - checked
    Went in Engine and the value is 00000? (Not saving)
    Re-did the coding, control module accepted it:
    When I went back though:
    This is really driving me nuts!!!
    Before this, I also did a scan of the codes and cleared them all.
    There was nothing major (I think?)
    Address 03: ABS Brakes Labels: 8E0-910-517.clb
    Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
    Component: ESP8 FRONT H06 0140
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004405
    Shop #: WSC 06325 000 00000
    VCID: 2C4F137B160BC26293D8325-8078
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 39
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4222
    Hex Value: 0x0024
    Hex Value: 0x0196
    Hex Value: 0x0001
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 Q
    Component: Lenksáulenmodul 0801
    Coding: 04041
    Shop #: WSC 06325
    VCID: 419152CF81893A3A50EE1B9-4B00
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    35-10 - - - Intermittent
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 CQ
    Component: Komfortgerát T3B 4336
    Coding: 11848
    Shop #: WSC 06325
    VCID: 02139DC3C40FE1220974CCD-4B1A
    Subsystem 1 - Part No: 8E2959802F
    Component: Tőrsteuer.FS BRM 0606
    Subsystem 2 - Part No: 8E2959801F
    Component: Tőrsteuer.BF BRM 0606
    Subsystem 3 - Part No: 8E0959801E
    Component: Tőrsteuer.HL BRM 0606
    Subsystem 4 - Part No: 8E0959802E
    Component: Tőrsteuer.HR BRM 0606
    2 Faults Found:
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    00955 - Key 1
    Cleared them all, took it for a spin and went back in Steering wheel, but there was no error anymore.
    The only thing I could think of is:
    Followed this guy's guide and changed 46 (Central convenience) to 11852. No errors there I see. Also removed the seatbelt chime using the same guide.
    B6/B7 S4 DIY: VAG-COM Modification Walk Through
    The only strange thing to the car I noticed is that when I open the driver's door, it shows as the passenger. Same applies to the passenger door which shows as driver's door. Think it's because I should have added +00218 for RHD
    Does anyone have any idea on how to make this CC work?
    P.S. Found this other guide that says further changes are needed to ABS, Steering Sensor etc.
    A4 Cruise.pdf - Google Drive
    Can anyone please help? I am leaving Thursday to Glasgow from Birmingham and really wanted to have this completed
    Any help is much appreciated!
    Oh and I've got the 2.0tdi 170 manual s-line
  2. Re: Please Help! Cruise Control Retrofit Won't Work
    131 Post(s)
    1973 Post(s)
    The engine ECU is coded for cruise, you can tell this by the letter G in the component description which stands for Geschwindigkeitsregelung. You can see the switch operations in engine measuring blocks, around group 66 if I remember correctly? Can you see the binary bit change for both the brake pedal switches and the clutch switch? They should read 1 with the pedal down and 0 with it up.
  3. Re: Please Help! Cruise Control Retrofit Won't Work
    Oct 2012
    Birmingham
    Hi Crasher,
    Thanks for your reply
    They do - checked them all there.
    So it's the 6th group where you can see the cruise control module with all the 1's and 0's. They all change when I move the CC.
    The only issue I used to have was about the clutch switch. Changed that now and it's all good in the sense that the values change when I press/depress the clutch.
    I am worried about the fact that the controller accepts the code, but when I go back it disappears?!
  4. Re: Please Help! Cruise Control Retrofit Won't Work
    131 Post(s)
    1973 Post(s)
    What, the "G" in "component" is not there when you go back?
  5. Re: Please Help! Cruise Control Retrofit Won't Work
    Oct 2012
    Birmingham
    Hey,
    I see in the screenshots that it stays there, but the code reverts to 0000 instead of 11463.
    Moreover, the cruise control does not want to work at all
    Anyone has a clue what should I do next? Clearly the stalk works, new clutch switch is in. Did the coding engine - 11463 (doesn't save) and steering wheel changed the 2nd to last digit to 4.
    I see this guide says you need to do more: A4 Cruise.pdf - Google Drive
    But I'm not sure that's relevant or not....
    Any help is much appreciated! (Getting ready for Glasgow drive now).
  6. Re: Please Help! Cruise Control Retrofit Won't Work
    131 Post(s)
    1973 Post(s)
    The coding value 11463 does not remain in the box when you return, the indication that it is activated is the letter "G" in the component box, if you enter the deactivation code, the "G" will disappear. Which retro fit kit did you use?
  7. Re: Please Help! Cruise Control Retrofit Won't Work
    Oct 2012
    Birmingham
    I was actually thinking earlier this might be the case...
    I have used:
    Looked around on forums and I can see that other owners have this one:
    If this was the case and I don't have the right one, shouldn't it not work when I access the group 06?
  8. Re: Please Help! Cruise Control Retrofit Won't Work
    131 Post(s)
    1973 Post(s)
    Lets go back to the beginning. You have a 2005>2008 8E with a BRD engine. Which stalk did you install, 8E0 054 690? From what I can see, you have the wrong steering column control module.
  9. Re: Please Help! Cruise Control Retrofit Won't Work
    Oct 2012
    Birmingham
    Hi Crasher,
    Thanks for taking the time to help me out - beer's on me.
    So I checked now and it's a BRD engine, the 170 hp version.
    The stalk that I bought has the code: 4E0953521
    Have my worst fears come true and i've bought the wrong stalk?
    Regards,
    Big.B
  10. Re: Please Help! Cruise Control Retrofit Won't Work
    131 Post(s)
    1973 Post(s)
    The stalk has chnaged part number to 4E0 953 521 B but what you have fitted is fine. I am a bit confused about the steering column controller being 8E0 953 549 Q which is only used on cars up to 2005 and together with a different column stalk, odd, ETKA says it should be 8E0 953 549 R and that the Q was dropped 10/2004. If the switch inputs can be seen in measuring blocks of the steering column controller and in th engine, I am a bit stuck.
  1. Mfsw and cruise retrofit finished- buttons don't work on wheel :(
    By blake1312 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-01-2015, 12:38 AM
  2. Please Help A4 cruise control wont work
    By Nick Bulmer in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 15-10-2012, 09:02 PM
  3. Please Help Cruise control does not work
    By kurtas2006 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-10-2011, 01:15 AM
  4. Cruise control retrofit?
    By css in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-12-2009, 10:06 PM
  5. Retrofit Cruise Control
    By trainer555 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-06-2009, 09:15 PM
