Thread: My A4 S Line with 20mm drop Eibach question ?
  1. My A4 S Line with 20mm drop Eibach question ?
    I have been thinking of swapping my 19" alloys for 18" to improve the ride but after reading many threads I might look at trying to tweak the suspension first , I am pretty sure I have the sport springs as I tried measuring from center of rear wheel to arch and its about 370mm and I think the s line option is 360mm ? The only thing is that although I seem to have to slightly more forgiving set up I would still like it a tad softer I know that Eibach do the Pro Kit with the 30mm but will this just lower it another 10mm than I already have and make it a bit stiffer , I liked this set up on a previous car I had that I used to track day in as the springs had some give before they would load up in the corners ( hence progressive ) the only thing is I don't really want to go lower if its not going to improve comfort .
    Does anybody run this set up and what do they think ? Or the Eibach Sport-line kit which is a 20mm drop ? As I don't have any experience with these ones , thanks for any pointers as long as its not to buy an SE
    "Dream as if you'll live forever. Live as if you'll die today."
  2. Re: My A4 S Line with 20mm drop Eibach question ?
    Jul 2010
    Staffordshire
    S line suspension is very poor and crashes over bumps. My S line mk2 TT was the same and changed to Eibach pro kit and was such a nicer ride. Changing from 19 to 18 will be hardly any difference to be honest.
  3. Re: My A4 S Line with 20mm drop Eibach question ?
    Quote Originally Posted by dubvrs View Post
    Ok ok thanks but did your TT originally have the sport suspension with 20mm drop or the s line option 30mm drop ? I.e was it lower after fitting the eibachs or the same height ? Thanks again.
  4. Re: My A4 S Line with 20mm drop Eibach question ?
    I looked into it and it looks like the eibach Pro kit will lower my sport suspension a further 10mm bringing it the same height as the s line 30mm option .
    But what I really need the know is will it also improve the ride quality even though it's 10mm lower ?
    also could I just fit se springs straight on with my shocks if I wanted ?
    thanks for any pointers.
  1. Eibach Pro kit springs on B8 S-line
    By Audidua in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-12-2015, 01:03 PM
  2. A6 S Line 30 mm suspension drop
    By k6rff in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 29-06-2014, 12:46 PM
  3. 20mm spacers on a3 05 2.0 tdi
    By stinkytoad in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-11-2013, 11:07 PM
  4. 18" and 30mm drop or 19" and 20mm drop?
    By frosth in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-09-2008, 09:14 PM
  5. S-Line 20mm ~ 30mm drop pic's
    By hoju99 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-06-2008, 12:15 AM
