Thread: Elastic auto box
  1. Elastic auto box
    Oct 2015
    Ayr
    That's what it feels like a lot of the time especially when cold. You press the pedal nothing happens then whoosh you're off. The mechanic I use changing the oil to see if that helps, I've had a few autos but nothing like this
  2. Re: Elastic auto box
    46 Post(s)
    Which engine/drivetrain?
  3. Re: Elastic auto box
    Oct 2015
    Ayr
    05 2.0 tdi you probably mean is it cvt ect don't know all I do know is that it can be used as "manual" when the levers moved to the left. I quite often use it like when cold as it takes ages to change in auto mode. But it's this "elastic band" type symptom especially when cold, plus Audi auto boxes don't get a good rep at the best of times
  4. Re: Elastic auto box
    46 Post(s)
    Ok so multitronic, has it had its 39k oil and filter changes religiously?
    The tiptronic and s-tronic gearboxes are pretty reliable, it's just the multitronic (cvt) which gets a bad name.
  5. Re: Elastic auto box
    133 Post(s)
    1987 Post(s)
    A Multichronic is a single speed constantly variable transmission, not an automatic, with any perceived steps being artificially created by the box placing the drive belt in a particular position to simulate a gear ratio. All these boxes have that rubber band feeling, it's how they are.
    We have a 100K mile 2009 A6 2 litre TDI which is probably going to be broken for spares as the Multichonic has let go in a big way and fixing it will cost more than the car is worth, 2009!
  6. Re: Elastic auto box
    Oct 2015
    Ayr
    Quote Originally Posted by Chris View Post
    yes has good history....just my #%^*++= luck
    Again, that's good to know...I knew I should have stuck to a manual ford
  1. Which Auto Box
    By The Technician in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-04-2014, 09:08 AM
  2. Question Giant elastic band behind radio - do you have one
    By bambamjj in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-09-2011, 08:54 PM
  3. auto box
    By jimmac in forum New Member Introductions
    Last Post: 23-05-2009, 11:25 AM
  4. engine change auto box to manual box
    By socrates1743 in forum Chat - Anything with wheels
    Last Post: 29-02-2008, 06:32 PM
  5. auto box
    By vr4stuart in forum Polo - Derby - Lupo - Fox
    Last Post: 28-04-2007, 10:33 AM
